Yes, it has been done a few times by members here. It is expensive to have done if you plan on paying someone to do it. The mounts themselves are not that expensive. The whole body has to be lifted to get to the front two from what I read. You can use F250 mounts if I am not mistaken. They are the same mounts used as the Excursion.
Either f250 or f350 mountd will work if I'm not mistaken. I also believe that the excursion has 2 more bodyssey mounts than the trucks do.
can anyone confirm ?
