brake conversion
Old Mar 15, 2010 | 08:30 PM
custom cabby's Avatar
custom cabby
brake conversion
I just picked up my '59 and it has the disc conversion on the front but I believe (have yet to measure) that it is still the 5x5.5" bolt pattern and I am having trouble finding any info out on the set up. Does anyone happen to know what I have or if there is a way I would be able to tell?
Old Mar 16, 2010 | 12:47 AM
Julies Cool F1's Avatar
Julies Cool F1
You can get the kits with either 5x5.5 and 5x4.5 (or a GM pattern if you prefer) Your PO probably got the 5x5.5 to keep the stock wheels!
Here are a couple threads about the conversions. You might want ot pick out someone who sounds knowledgeable and send them a PM as well!
https://www.ford-trucks.com/forums/8...new-drums.html
https://www.ford-trucks.com/forums/5...ake-drums.html
https://www.ford-trucks.com/forums/8...-end-savy.html
Good luck!
Old Mar 16, 2010 | 03:33 AM
malatious's Avatar
malatious
When I was checking into it all the kits looked like they came from the same suppliers.
If you have the 5 x 5.5 bolt pattern the rotors should be from a 73-93 F-100/F-150 (or Ford equivalent) and the calipers are from a 71-87 GM ½ Ton Truck (Or GM equivalent) .
A2 Outer Bearings
A13 Inner Bearings
44053 Bearing Seals
Here is a link to CCP's instructions for there kit:
Classic Performance Products
I just bought the bracket kit and then went out and bought all the other components from local parts stores and it was not a problem. The only odd thing to be aware of is that every time you replace the rotors you will need to replace the outer bearing race on the new rotors.
juang316
Sep 25, 2013 07:24 PM
bpete
Aug 20, 2013 06:31 PM
fordtruckman2001
Dec 23, 2010 04:30 PM
1ford1
1997 - 2003 F150
Jul 17, 2008 06:34 AM
countryboy4_1qt
Jan 31, 2007 04:35 PM
