1951 F1 Brake Drums
1951 F1 Brake Drums
Yes there are some other Ford brake drums that work. Unfortunately, I don't know what they come from. In an attempt to get my 49 F1 rolling and avoid the high price of new brake drums I scouted around the local bone yard and found two Ford drums that work just fine. They are 11" x 2 ½" instead of the original 11" x 2". The hub size, bolt pattern and offset is a perfect fit. You just end up with a wider surface then you need. Not a problem.
Unfortunately, I found the drums in a pile of parts and have no idea what they originally came off of. I'm guessing something in the 70's or 80's. I have the parts numbers from the drums but have not been successful in cross referencing to see what they originally fit. If I knew what to order, new ones would probably be more reasonable priced at some place like Autozone.
By the way, I probably should not admit this around here but the 11" x 2" brake shoes and self adjusting brake hardware that I'm using came off of a 71 chevy ½ ton. Works just fine. I'm keeping that a secret from my F1. I would not want to intentionally hurt the old girls feelings.
1951 F1 Brake Drums
Brake shoes probably, Brake drums no. As far as I know, 48-52 F1 brake drums are unique. I would be interested in hearing what Autozone comes up with. Autozone's computers go back farther then most and sometimes they do have what you need. When I was rebuilding the wheel cylinders last month, I was surprized to find that they had them in stock, and cheap. Not just the kit, but new wheel cylinders. They probably fit a bunch of other vehicles.
Good luck.
Good luck.
1951 F1 Brake Drums
thejerold has it right - try NAPA. I couldn't find a brake cylinder rebuild kit for my F2 and NAPA had them shipped in from the warehouse the next day. In fact the local store had a replacement circuit breaker in a box when I went in to see if they could order one. NAPA
Better late than never?
I know this is an old question but I was looking at it so maybe someone else is too. I was also in need of front drums for my 1951 M1 project (Mercury version of an F1). I was at a wrecking yard today and found an 11" rear drum from a 1984 Ford F150, almost identical in features needing 1 small modification. ( open the stud holes to 5/8" from 9/16" ( 'cause the studs have shoulders). I gave the guy at the yard $5 for an old one so I could do some R&D, everything's looking good and the local NAPA has new USA made ones in stock for $35 /drum.
Just an option to the $100 drums the specialty guys are selling.
They don't have a dished face - they're a typical drum. I'm thinking that if the wheel is designed for the deeper drum what you'd have is a 2 1/2" drum with a 2" brake shoe. I'm not sure how that might work in a daily driving situation.
I too want to check it out a bit - I've got an 82 and an 84 parts trucks sitting in the pasture. Maybe I'll be motivated enough to shovel snow to dig them out - or just wait till spring
