5.8 to deisel conversion
Old Dec 22, 2010 | 04:41 PM
fordtruckman2001's Avatar
fordtruckman2001
i have a 1994 f250 with a 5.8 5 speed. i also have a 1995 e350 with a powerstroke. will that power stroke bolt up to the bell housing of the 5 speed in the f250?
Old Dec 22, 2010 | 04:53 PM
rla2005's Avatar
rla2005
No it will not.
Old Dec 22, 2010 | 04:59 PM
zxwut?'s Avatar
zxwut?
Is the transmission in the e350 dead?
Old Dec 22, 2010 | 05:08 PM
Diesel_Brad's Avatar
Diesel_Brad
Transmissions are different. You need a diesel trans. And you will need to swap the whole harness to run the powerstroke. You also need a larger radiatior and a bunch of other diesel specific things, not a simple swap
Old Dec 22, 2010 | 06:17 PM
fordtruckman2001
i have the whole van for all the swap. but the van is a 2 wheel drive with a good trans. the truck is a 4 wheel drive plow truck. so can i put the transfer case on the auto trans?
Old Dec 22, 2010 | 06:54 PM
rla2005's Avatar
rla2005
Yes you could, but you need to completely disassemble the transmissions to swap the output shaft and tail shaft to do so.
Old Dec 22, 2010 | 07:41 PM
fordtruckman2001
cool thats not that bad then. might be worth the swap in the summer
Old Dec 22, 2010 | 08:15 PM
Diesel_Brad
He will need a e4od rear tail shaft and housing. the zf5 parts will not work on the e4od
Old Dec 22, 2010 | 08:17 PM
Diesel_Brad
the van radiatior will not fit in the gas truck rad support. You will either have to graft the lower part of the van rad support in or get a diesel truck rad support.
not sure if the van dashboard will fit in the truck
not sur if the van engine mounts and perches will work in the truck
Old Dec 22, 2010 | 08:32 PM
rla2005's Avatar
rla2005
Good point Brad, I missed that part about the different transmissions.
Old Dec 22, 2010 | 08:42 PM
Diesel_Brad
FORDTRUCKMAN2001 You should put the powerstroke in your avatar. that would be awesome
Old Dec 23, 2010 | 04:30 PM
fordtruckman2001
that van is getting a 351 mod mounted about mid way for a wheely cool dragster. its a 1963 econoline travel wagon. i think i might have to for get the conversion. i will try to find a truck with a blown motor. thanks for all the info.
joe Ironworker
Feb 6, 2013 09:03 AM
SC 1980
Jan 9, 2012 05:10 PM
dhoffman45
Jan 7, 2007 08:31 AM
merkstang
Mar 23, 2006 10:04 AM
warrior777
Jan 7, 2004 06:10 PM
