LV Information
Old Nov 10, 2019 | 05:15 PM
  #46
bismic's Avatar
bismic
Lol - that procedure wasn't out in 2010 when this thread was active.
Regardless - good to have it documented in this old thread for all the internet searchers!
Old Nov 10, 2019 | 05:33 PM
  #47
S.A.E.'s Avatar
S.A.E.
4wd Low
Yes,, these forums have no time lapse nor updating for information obsoletion!
I use posts form nearly 2 decades ago for my 7.3 and 6.0
Old Nov 10, 2019 | 07:08 PM
  #48
Ford.Dude's Avatar
Ford.Dude
Thanks for the resurrection of this old thread. Never came across this one. I still haven't figured out if it's okay to mix SP and LV. Book marketing this for later reading.
Old Nov 11, 2019 | 01:33 PM
  #49
69cj's Avatar
69cj
All I can say is that I did it on my 05 and never had any problem.
Old Nov 11, 2019 | 01:41 PM
  #50
AL`'s Avatar
AL`
See quote below from post #24 of this thread.
Originally Posted by PowerStrokeHD
This was released on 11/26/09 and is the most up to date info...
MESSAGE TITLE: REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
APPLICABLE VEHICLES :
2003 - 2005 TRUCK : 00126 EXCURSION
2003 - 2008 TRUCK : 00028 F-SERIES
2004 - 2008 TRUCK : 00016 E-SERIES
2006 - 2008 TRUCK : 00175 F-SERIES MOTORHOME
2006 - 2008 HEAVY TRUCK : 00168 LOW CAB FORWARD
OASIS MESSAGE :
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND
2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD
BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP.
THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON
SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE.
USE MERCON LV TRANSMISSION FLUID
TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR
REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT
TRANSMISSION, USE MERCON LV TRANSMISSION FLUID.
Reference: SSM 21114
Old Nov 11, 2019 | 03:16 PM
  #51
High_HP's Avatar
High_HP
I thought the rumor was Ford dropped the LV recommendation and went back to SP recommendation due to issues with the LV fluid. Just a 'rumor'?
Old Nov 11, 2019 | 05:23 PM
  #52
Ford.Dude's Avatar
Ford.Dude
That's the rumor I read.
Old Nov 11, 2019 | 05:27 PM
  #53
bismic's Avatar
bismic
Looks like LV is still the recommended fluid on this chart from Ford
https://www.fcsdchemicalsandlubrican...ref/atf2US.pdf
and here
https://www.fcsdchemicalsandlubrican...ission%20Fluid
Old Nov 11, 2019 | 06:10 PM
  #54
AL`'s Avatar
AL`
I'm surprised SP is still on the market after all these years. Thought it was being phased out. It's more expensive than LV though. I bought a bunch of LV years ago in anticipation of doing several drain/fills to change out fluid, but ended up doing the cold flush method when I found out about it. So I have a bunch of LV left as a result.
Bought mine from Ryder Fleet Products. Best price I could find at the time for $3.91/qt.
Old Nov 11, 2019 | 06:25 PM
  #55
bismic's Avatar
bismic
This chart shows why SP hasn't been phased out. Two transmissions require it
https://www.fcsdchemicalsandlubrican...kref/atfUS.pdf
Old Nov 11, 2019 | 06:59 PM
  #56
Ford.Dude's Avatar
Ford.Dude
Bis....you are the man!
Awesome find and thank you sir. One hell of a relief for me. I bought a case of LV a few months back then upon more searching I found other info that says it may have been a waste of money for me.
hatchet
16
Sep 10, 2019 07:54 PM
BAD RONALD
Jun 10, 2013 09:48 PM
nolanb
May 11, 2010 06:27 PM
ccerniglia
Oil & Lubrication
18
Oct 17, 2008 10:51 PM
shotgun_000
Jan 28, 2006 06:22 PM
