LV Information
Old Feb 22, 2010 | 07:58 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Originally Posted by smokersteve
I thought so too... Auto zone and other stores are selling sp so that also got me thinking that SP was going away
Wow, "SP" in big box stores? How much they charging for it? I'll be on the lookout.
Old Feb 22, 2010 | 08:55 PM
ljutic ss's Avatar
ljutic ss
[quote=bismic;8550291]So now it seems that they have officially changed the recommended 5R110 Torqshift fluid .........
Sure is confusing how they worded things in your first post!!
I don't think that I would mix the two though - just enough questions on these posts to concern me a little.[/quot
At the time (last month) I was told at the Ford dealer where I get supplies from that the SP and LV could be mixed. They even printed out a service bulletin showing you could top off the SP with LV. I went and put 8 quarts of LV in with my SP after draining the pan. So far 1,000 miles and no change in shifting.
Old Feb 22, 2010 | 09:45 PM
smokersteve's Avatar
smokersteve
more than you should...
Dieselfiltersonline has sp at a good price.
Diesel Transmission Fluids - [XT-6-QSP] Motorcraft MERCON® SP Automatic Transmission Fluid - Quart
Ryder
Motorcraft ATF Transmission Fluid Mercon SP XT6QSP
K-man
Motorcraft TorqShift fluid XT-6-QSP Mercon SP
Old Feb 22, 2010 | 09:46 PM
smokersteve
[quote=ljutic ss;8551096]
Good to hear
I would like to use LV since it is new and all...
Old Feb 22, 2010 | 10:01 PM
bismic's Avatar
bismic
I just was informed that the information in the fcsd website is "out dated". The information from ljutic ss is the most current - THANKS!
Old Feb 22, 2010 | 10:06 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by 69cj
Fritts Ford in Riverside charged me 133 for SP hot flush.
That wasn't with the filter, was it? If it was, it's worth the drive out there.
I paid 175 at Grody in Buena Park, but that included the filter.
Old Feb 22, 2010 | 10:13 PM
rocky1074's Avatar
rocky1074
I purchase my Mercon SP at Ryderfleetproducts.com they charge 4.68 per qt. You must purchase 12 minimum @ 56.16 plus 7.95 shipping. Total 64.11 delivered to your door. I already purchased 2 cases from them..
Comes to 5.34 per qt delivered to your door Diesel filters online cost 5.49 per qt before delivery...
Old Feb 22, 2010 | 10:37 PM
smokersteve
Ryder is very cheep
Old Feb 22, 2010 | 10:38 PM
PowerStrokeHD's Avatar
PowerStrokeHD
This was released on 11/26/09 and is the most up to date info...
MESSAGE TITLE: REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
APPLICABLE VEHICLES :
2003 - 2005 TRUCK : 00126 EXCURSION
2003 - 2008 TRUCK : 00028 F-SERIES
2004 - 2008 TRUCK : 00016 E-SERIES
2006 - 2008 TRUCK : 00175 F-SERIES MOTORHOME
2006 - 2008 HEAVY TRUCK : 00168 LOW CAB FORWARD
OASIS MESSAGE :
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND
2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD
BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP.
THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON
SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUID
TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR
REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT
TRANSMISSION, USE MERCON LV TRANSMISSION FLUID.
APPLICABLE SYMPTOM CODES :
500000 DRIVELINE
504000 DRIVELINE OTHER AUTO TRANS CONCERNS
510000 DRIVELINE FLUID CONCERNS
Reference: SSM 21114
Old Feb 22, 2010 | 10:42 PM
smokersteve
OASIS MESSAGE :
500000 DRIVELINE
Sweet
Do you guys know of an online store that sells LV?
Old Feb 22, 2010 | 10:55 PM
smokersteve
Where at Steve? Fritts Ford in Riverside charged me 133 for SP hot flush. I can't do it for that.
I will do it my self. Drain all the lines and stuff
Old Feb 23, 2010 | 08:10 AM
ljutic ss's Avatar
ljutic ss
[quote=bismic;8551457]
Originally Posted by ljutic ss
I just was informed that the information in the fcsd website is "out dated". The information from ljutic ssis the most current - THANKS!
Mark, I was relieved to read your post, but you should have posted it before 10:30 last night. I went to bed thinking Ford revised their information on the compatibility of SP and LV. I had a hard time falling asleep, wondering how much a trans rebuild would cost me.
P.S. Last month LV was $4.16 a quart +tax.
Old Feb 23, 2010 | 09:29 AM
  #28
69cj's Avatar
69cj
Torqueshift has a t-stat in it. You can't drain the 8 to 10 qts. in the torque converter without a hot flush.
Old Feb 23, 2010 | 10:05 AM
  #29
smokersteve
O ok thanks
Old Feb 24, 2010 | 10:40 PM
  #30
smokersteve
Is this legit?
$3.96
Motorcraft XT10QLVC Oil/ATF Fluids - Buy MTC-XT10QLVC Online at Wholesale or Jobber Price
