Sponsored by: Real Truck
Transmission fluid question
Old May 11, 2010 | 11:45 AM
nolanb's Avatar
nolanb
Hey guys,
I'm trying to figure out what transmission fluid to use in my truck. Its a 2002 f250 super duty 6.8L v-10 4x4 with an auto. I've looked in the owners guide and cant for the life of me figure out what type of transmission i have. Do I need to know what type of fluid to use or is it just the mercon ATF as is says in the owners guide? Also how much fluid do i need. 17 quarts??? damn that seems like alot. Thanks
Old May 11, 2010 | 12:00 PM
MikeMcCasland's Avatar
MikeMcCasland
nolanb,
Yes, your manual/trans does technically call for Mercon transmission fluid. That being said Mercon V is backwards compatible with Mercon fluid. It’s getting very difficult to find a Mercon only spec fluid since Mercon V was released. There were some issues with Mercon V being used in Mercon speced transmissions when it was initially released. As a result, there are still some people touting anecdotal claims that you cannot use Mercon V stuff in a 4R100. Ford says you can, and Mark K. (Former Ford Senior Trans Engineer who posts on here) says you can so that’s good enough for me.
I’d go grab 20 quarts of Mercon V fluid and swap the fluid.
Old May 11, 2010 | 12:43 PM
bpounds's Avatar
bpounds
Use Mercon VEE
Old May 11, 2010 | 02:15 PM
nolanb's Avatar
nolanb
So should i do the whole flush or just drop the pan and put 7-8 more quarts? Also how do you go about a whole fluid flush?
Old May 11, 2010 | 02:22 PM
MikeMcCasland
I drop the pan just to wipe all the clutch material off the magnet. If it were me I'd do a full flush, otherwise whats the point?
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Old May 11, 2010 | 04:33 PM
bunklash's Avatar
bunklash
Dang you Bill, I nearly googled Mercon VEE to see it there was a newer Mercon, figuring the EE stood for Extra Engineered or something. Where's my sign?
Old May 11, 2010 | 06:27 PM
bpounds's Avatar
bpounds
We all have them.
ethomps
24
Aug 29, 2021 12:19 PM
Subzero68
Sep 19, 2014 07:45 PM
dieterschmied
Apr 18, 2011 10:20 PM
sfafarley
2004 - 2008 F150
Aug 7, 2009 06:41 PM
fastcarz3
Feb 2, 2006 01:45 PM
