LV Information
Old Feb 24, 2010 | 10:44 PM
  #31
smokersteve's Avatar
smokersteve
some info
http://www.fordtechservice.dealercon...09Hotsheet.pdf
Old Feb 24, 2010 | 10:49 PM
  #32
ljutic ss's Avatar
ljutic ss
That price sounds legit, my dealer charges me $4.16 I am glad the cost of our trans fluid has come down to a reasonable price.
Old Feb 25, 2010 | 10:06 AM
  #33
smokersteve
Thanks ya 4$ for a full syn trany fluid is great
Old Feb 25, 2010 | 10:22 AM
  #34
UGA33's Avatar
UGA33
Just had my tranny flushed last week with LV. It is shifting better than ever. I am able to get parts at cost and paid 3.97/qt for the LV fluid, $22 bucks for the filter, and a heated flush by my diesel tech buddy at the dealer for a whopping total of $110. It doesn't smell as bad as the SP. Anyone else notice that?
Old Feb 25, 2010 | 11:31 AM
  #35
ljutic ss's Avatar
ljutic ss
I picked up a case around Xmas and that was the 1st. thing I noticed, now if only they can make the rear lube smell that pleasant.
Old Feb 25, 2010 | 12:23 PM
  #36
03-6L-X's Avatar
03-6L-X
Originally Posted by SteveBricks
That wasn't with the filter, was it? If it was, it's worth the drive out there.
I paid 175 at Grody in Buena Park, but that included the filter.
Checked with the "deal"erships in my area and only one offers hot flush and the cost is $375.00 that includes a new screen and external filter.
Old Feb 25, 2010 | 01:21 PM
  #37
rocky1074's Avatar
rocky1074
The price is legit..I checked it out
12 qts 47.52;
Shipping 31.75;
A $3.00 Special Order Fee Applies to Orders Under $50.00. Total 82.27 Comes to 6.85 per Qt. Not such a good deal..
Old Feb 26, 2010 | 08:49 PM
  #38
mh5500's Avatar
mh5500
Well, I'm realy confused. Called 3 Ford dealers today and didn't get a staight answer from none of them. Can you use LV in a 2003 F-250 6.0? Can you just drain the pan and add 8 quarts of LV with the SP thats left in there?
Old Feb 26, 2010 | 09:01 PM
  #39
03-6L-X's Avatar
03-6L-X
At the time (last month) I was told at the Ford dealer where I get supplies from that the SP and LV could be mixed. They even printed out a service bulletin showing you could top off the SP with LV. I went and put 8 quarts of LV in with my SP after draining the pan. So far 1,000 miles and no change in shifting.
This says you can mix the two. Guess if you want to be totally safe have the dealership change it or go to a Transmission shop you trust with the LV and have them do the total flush for you.
Old Feb 26, 2010 | 09:29 PM
  #40
ljutic ss's Avatar
ljutic ss
Originally Posted by mh5500
Well, I'm really confused. Called 3 Ford dealers today and didn't get a straight answer from none of them. Can you use LV in a 2003 F-250 6.0? Can you just drain the pan and add 8 quarts of LV with the SP that's left in there?
This is what I did shortly after Xmas, drained the pan and added 8 qt. of LV. Also I changed the inline filter, now every other motor oil change I will replace 8 qt. and a new filter. I will also send a sample to Blackstones for an analysis the 1st. time. The Ford dealer printed out a service bulletin stating the 2 fluids could be mixed in our transmissions.
Old Feb 27, 2010 | 06:12 AM
  #41
mh5500's Avatar
mh5500
Have you noticed any difference?
Old Feb 27, 2010 | 06:41 AM
  #42
ljutic ss's Avatar
ljutic ss
No difference in shifting, next time your at a Ford dealer ask the parts person to print out the service bulletin on the new LV fluid. It explains that the 2 fluids can be mixed.
Old Apr 12, 2010 | 10:39 PM
  #43
smokersteve
Ryder now sells LV!!!! $3.92!!!!!!
Motorcraft Transmission fluid LV XT-10-QLVC
Old Apr 13, 2010 | 12:01 AM
  #44
rickf92592's Avatar
rickf92592
Lucas has come out with a SP/LV compatible fluid. It's not on the website yet but it works!
Called "Multi-Vehicle ATF", not too sexy but the specs are; super high flash point.
Old Nov 10, 2019 | 05:05 PM
  #45
S.A.E.'s Avatar
S.A.E.
4wd Low
Originally Posted by 69cj
Torqueshift has a t-stat in it. You can't drain the 8 to 10 qts. in the torque converter without a hot flush.
Yes you can. Simple:
