LV Information
Old Feb 22, 2010 | 05:35 PM
smokersteve's Avatar
smokersteve
LV Information
highlight entire line for the link
http://www.fcsdchemicalsandlubricant...roduct=MERCON® LV Automatic Transmission Fluid&category=Transmission Fluid
<TABLE border=0 cellSpacing=5 cellPadding=0><TBODY><TR><TD vAlign=top>
</TD><TD>Motorcraft® MERCON® LV is a premium-quality automatic transmission fluid designed, engineered and recommended by Ford Motor Company for use in Ford, Lincoln and Mercury vehicles that require MERCON® LV type fluid. This product also provides excellent performance in electronically controlled automatic transmissions. Check Owner Guide and transmission fluid charts for application.</TD></TR><TR><TD vAlign=top>
</TD><TD>Motorcraft® MERCON® LV is manufactured with high-viscosity index, premium-quality, hydroprocessed base oils and specially designed performance additives, which provide excellent shifting characteristics at high and low ambient temperatures and guards against transmission shudder. This fluid has excellent thermal, oxidation and shear stability and good low temperature fluidity. It provides wear protection and inhibits the formation of gum, sludge, lacquer and foam. It also prevents against rust and corrosion. It is dyed red for ease of leak detection.</TD></TR><TR><TD vAlign=top>
</TD><TD>Do not use in applications where MERCON® V, MERCON® SP, Continuously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended, or in transfer cases.</TD></TR><TR><TD vAlign=top>
</TD><TD>Refer to the Motorcraft® MERCON® LV specification sheet below for additional information. For MSDS information call 1-800-448-2063</TD></TR><TR><TD vAlign=top> </TD><TD>Note: MERCON® LV Automatic Transmission Fluid is available in bulk quantities at substantial savings. Use of bulk oil products is environmentally proactive. Contact your FCSD Aftermarket Account Manager, an approved Motorcraft® Bulk Oil Distributor, or Motorcraft for details.</TD></TR></TBODY></TABLE>
Old Feb 22, 2010 | 05:42 PM
smokersteve
Highlight entire line for the link
http://www.fcsdchemicalsandlubricant...product=MERCON® SP Automatic Transmission Fluid&category=Transmission Fluid
</TD><TD>Motorcraft® MERCON® SP is a premium-quality fluid designed, engineered and recommended by Ford Motor Company specifically for use in Ford, Lincoln and Mercury vehicles that require MERCON® SP type fluid. This product also provides excellent performance in electronically controlled automatic transmissions. Check Owner’s Guide or Workshop Manual for correct applications</TD></TR><TR><TD vAlign=top>
</TD><TD>Motorcraft® MERCON® SP is manufactured with premium base oils and specially designed performance additives, which provide excellent shifting characteristics at high and low ambient temperatures, excellent thermal and oxidation resistance. It provides wear protection and inhibits the formation of gum, sludge, lacquer and foam. It also provides protection against rust and corrosion. MERCON® SP is friction modified for smooth transmission operation while guarding against transmission shudder</TD></TR><TR><TD vAlign=top>
</TD><TD>Specifically designed for improved durability and torque handling capacity in TorqShift™ transmissions</TD></TR><TR><TD vAlign=top>
</TD><TD>Do not use in transmissions requiring MERCON® V, MERCON® LV, Continously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid, or Type F Fluid</TD></TR><TR><TD vAlign=top>
</TD><TD>Refer to the Motorcraft® MERCON® SP specification sheet at Motorcraft and www.fmcdealer.dealerconnection.com for additional information. For MSDS information call 1-800-448-2063</TD></TR></TBODY></TABLE>
Old Feb 22, 2010 | 05:51 PM
bismic's Avatar
bismic
Nice post Steve!
Old Feb 22, 2010 | 05:52 PM
ljutic ss's Avatar
ljutic ss
Web site will not display.
Old Feb 22, 2010 | 06:00 PM
smokersteve
Originally Posted by bismic
Nice posts Steve!
WOW Bismic said nice posts STEVE!!! SCORE!!!
Thank you
Highlight the entire line and paste it in the search bar, dont click on it
Old Feb 22, 2010 | 06:02 PM
bismic's Avatar
bismic
I visit that web site quite a bit.
Looks like it might be the "registered" trademark symbol that may be messing the link up?? You can get to it through the main site and clicking on the applicable tabs:
http://www.fcsdchemicalsandlubricants.com/Main/
The interesting thing that I had not noticed before (maybe it was not included in the past on this web site) is the statement to NOT use it where Mercon SP is recommended. I had heard differently - so this needs some investigation!
Old Feb 22, 2010 | 06:03 PM
smokersteve
It is interesting to see that they state both lv and sp should not be used mixed in their uses and yet I have read many times that they can be, like LV in a 5r100, from the forums....
Old Feb 22, 2010 | 06:05 PM
smokersteve
looks like it is the "registered" trademark symbol that may be messing the link up. You can get to it through the main site and clicking on the applicable tabs:
FCSD Chemicals and Lubricants
Same here but I haven't been there in half a year. It took a while to find it again.
Old Feb 22, 2010 | 06:11 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Now my curiosity is building. I thought I read in the threads that the SP was going to completely go away and replaced by LV. My mind is now totally "boggled".
Thankfully I changed my tranny fluid before all this started, now have 28,000 miles to let everyone figure this out.
Sean
Old Feb 22, 2010 | 06:16 PM
smokersteve
Sean
I thought so too... Auto zone and other stores are selling sp so that also got me thinking that SP was going away
Old Feb 22, 2010 | 06:19 PM
smokersteve
Originally Posted by fordmasterdieseltech
ford says to use it, so I would go with it. ive used it alot lately in many torqueshift trans with no issues.
I just talked to this guy and he is even saying we should use it....
I am not posting this to tell everyone to only use LV I am just trying to figure out it it is FULLY compatible in OUR trans.
Old Feb 22, 2010 | 06:22 PM
smokersteve
http://www.fcsdchemicalsandlubricant...ickref/atf.pdf
Just found this.
Old Feb 22, 2010 | 06:29 PM
bismic's Avatar
bismic
So now it seems that they have officially changed the recommended 5R110 Torqshift fluid .........
Sure is confusing how they worded things in your first post!!
I don't think that I would mix the two though - just enough questions on these posts to concern me a little.
Old Feb 22, 2010 | 06:37 PM
smokersteve
I agree, I think I will wait a while for other people to do this.
I have to change my trans fluid but I haven't found a place that is cheap.
Old Feb 22, 2010 | 07:44 PM
69cj's Avatar
69cj
Where at Steve? Fritts Ford in Riverside charged me 133 for SP hot flush. I can't do it for that.
