Wow. this thing is almost confusing to use.
Needs about 3 more buttons and a jog wheel, or at least just a jog wheel to go though the menu's.
Some are so long they are a pain to go all the way though to get back to the one right above.
so I have it on good authority that the guy that bent over backwards to get us the gauges available hasn't even laid the cable out across the dashboard, stuffed the gage in the corner, zip tied under the glove box a couple times plugged it in to the OBD PORT YET.
SO here's where you come in, I need a little help to 'motivate' our friend and sponsor a little. c'mon Jim. you should be able to at least plug it in. shoot I think I did mine on my lunchbreak with a sandwich in one hand It could give you lots of good info about your injectors and installs.
HA!
See Jack, I did at least plug it in to see what it looks like.
Then unplugged it, stuck it back in the box and put it with the rest of the gauges that never got installed.
That's literally as far as I've gone with the scan gague...
When you do get some time to put in all your gages, I think you will find a lot of useful info. on the scangage for your business. I know I'm not the only one that thinks a complete install requires a healthy amount of duct tape and zip ties
