2001 cold start loaping
Old Feb 26, 2003 | 12:32 AM
  #46
JoeBoost's Avatar
JoeBoost
Just for the record , my 2002 Excursion PSD with 15,000 miles does the same violent loaping thing when i try to start it when it has not been plugged in overnite. It usually takes two or three tries before the truck will actually want to idle. Seems to only do this when the temp is under 20 ......
Old Feb 26, 2003 | 12:35 PM
  #47
psd tech's Avatar
psd tech
JOEBOOST, I'm sure you have seen the posts regarding the 10w30 oil. What are you running for oil ?
Old Oct 16, 2003 | 08:00 AM
  #48
LARRYSHAN20
Guest
Posts: n/a
Can anyone tell me where to buy 10W-30 Approved for diesels?
I have the problem with loping, the local Ford dealer doesn't have it and the guy at Auto-Zone says there is no such animal.
Old Oct 16, 2003 | 08:57 AM
  #49
spartamouse1's Avatar
spartamouse1
motorcraft makes a 10w30 "diesel" oil. any ford dealer should be able to get it. ford # is XO-10W30-QSD
Old Oct 16, 2003 | 11:59 PM
  #50
diesels revenge's Avatar
diesels revenge
my truck has done the same thing since it was new 40,000 miles on it here in chilly michigan I have always just touched the gas pedal and it stops I just figured it was part of the deal with the truck.
Old Oct 17, 2003 | 06:57 AM
  #51
brus01psd's Avatar
brus01psd
I have a 2001 with same condition. However around 30k, my truck ran rough even after warm up. It would cough, sputter, and die frequently. Took it to the dealer, they replaced the cam timing senser. The tech told me this is a common problem, as is the loaping on startup. Since then it loaps once, maybe twice (not nearly as violent as before) then clears up. I use shell rotella 15-40 year round.
natew
Nov 16, 2015 12:22 PM
flatbed444E
17
Mar 20, 2015 09:34 AM
MarkProctor
Escape & Escape Hybrid
Dec 19, 2014 08:01 PM
Alishia Smith
Dec 19, 2014 07:05 PM
JerryG008
Dec 20, 2010 08:25 PM
