2001 F350 7.3L hard start rough idle
Old 12-19-2014, 01:26 PM
Alishia Smith
Alishia Smith is offline
Alishia Smith is starting off with a positive reputation.
Ok. I have a 7.3l. When started it loaps then after a few seconds it runs fine. Replaced HPOP oil lines fuel water seperator valve fuel filter IPR valve ICP sensor. When driving it today it died. Restarted and rough idle kept it at 2000rpm and started to drive home. Could feel the tryck jerk and the gas pedal jerk under my foot. Then it jerked really hard and died again. Tried to start it wouldn't. I unplugged the ICP and it started. Got it home. What is wrong with my truck. Help!!!
Old 12-19-2014, 07:05 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is online now
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
When you unplugged the ICP the PCM defaults to a set value so it will run. I betcha the ICP and connector are wet with oil. If so, you need a new ICP. Genuine Ford or IH is really better than the cheap parts store stuff in this case. Costs more, but better.
Quick1996
06-13-2017 08:58 PM
Johngersna
1999 to 2016 Super Duty
10-11-2016 06:15 PM
TxFord1969
03-26-2016 09:24 AM
upslash
1997 - 2003 F150
01-18-2016 12:58 PM
emtabmm
01-01-2004 08:22 PM
Quick Reply: 2001 F350 7.3L hard start rough idle
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
