Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 Ford Escape V6 Starting Problems
Old Dec 19, 2014 | 02:43 PM
MarkProctor's Avatar
MarkProctor
My daughter has a 2001 Ford Escape, V6, Automatic, 2WDR, 132,000 miles that is having starting problems. When you turn the key the engine will try to start. You have to push on the gas pedal to keep it running, it will not idle until it gets warmed up. If you try to drive it while cold, it has no power. Reading previous posts I have already replaced the spark plugs, intake gaskets, air filter, EGR, TPS, and fuel filter. Check for crack hoses / vacuum leaks. It is still not starting properly. No engine codes. New problem is oil light is flashing but the engine has oil. All of the gauges, lights, functioning normally. Very Frustrating. What do I try next?
Old Dec 19, 2014 | 08:01 PM
bmuhlbach's Avatar
bmuhlbach
IAC Valve could be bad.
Charlie Doc
Modular V10 (6.8l)
15
Jan 28, 2013 05:07 PM
dawson2381
Mar 26, 2007 07:46 AM
Windwalker
Aug 12, 2004 07:40 AM
glenplake
1997 - 2003 F150
Aug 24, 2003 10:51 AM
