Boost fooler recomendation
Feb 18, 2010 | 08:30 PM
I recently ordered a boost relief valve from advance diesel. Is there a noticable difference from that and the boost fooler from itp ?
Feb 18, 2010 | 08:33 PM
Feb 18, 2010 | 08:38 PM
i wonder if this would be beneficial on a 6.0l
Feb 18, 2010 | 08:52 PM
A boost relief valve releases boost above approximately 22 psi before it reaches the MAP sensor so the PCM does not see overboost and defuel.
An overbosst fooler does not release boost but limits what will pass to the MAP to approximately 22 PSI to prevent defueling.
They each have there downside. A relief valve lowers boost. It essentially becomes a small boost leak when it opens.
An adjustable fooler can go out of adjustment and allow to much boost to get to the MAP and causes defueling.
I have an adjustable fooler which needs ocasional adjustment. I have ordered the OCR referred to by Mike (Big Poppa) to replace it.
My 2¢.
Feb 18, 2010 | 09:07 PM
So is it worth it to send the regulator back for the fooler or should I just roll with the one I ordered from advancediesel.com ?
Feb 18, 2010 | 09:14 PM
Personally I would just rather adjust tuning so you don't need either.
Feb 18, 2010 | 10:00 PM
Maybe Im confused then. I thought I needed the relief/fooler to keep the fuel from tripping out. So how would I "tune" anything ?
Feb 18, 2010 | 10:20 PM
Quote:
Originally Posted by
jdamato1
Tuning would involve after market tuners such as DP, PHP, Tony Wildman or TS Performance. They can program tunes so the PCM will not defuel due to overboost.
Feb 18, 2010 | 10:28 PM
I'm getting my ts chip Custom burned from wildman. So if I tell him I need that option he can set it up so it won't trip out ?
Feb 18, 2010 | 10:37 PM
jdamato1
I'm sure he can, but he is the one to answer your question.
Feb 19, 2010 | 07:32 AM
big poppa
I have this version from Riffraff. It's a very professional looking version... very well put together with Riffraff's special attention to detail. the installation instructions are spot on and everything you need is included.
Feb 19, 2010 | 10:17 AM
i also have the riff raff OCR along with dp no codes tunes and no cel to speak of
i was under the impression that with codes tunes u can still get a cel but it wont defuel thats y i went with both
mikec91
16
Apr 19, 2013 12:26 PM
036liter
Jan 12, 2012 02:30 PM
ford4x4956
Jul 21, 2009 10:33 AM
redneckboy
Dec 4, 2007 01:06 PM
crack
33
Sep 20, 2007 04:52 PM
60 ,
73 ,
73l ,
adjustable ,
advancedieselcom ,
boost ,
diesel ,
fooler ,
ford ,
forums ,
itp ,
map ,
powerstroke ,
relief ,
valve
