Boost fooler
Old Dec 2, 2007 | 11:51 PM
redneckboy's Avatar
redneckboy
Boost fooler
Where can I get a boost fooler that you can also tap the boost guage into it.
The T method just sucks and im tired of it. Thanks for the help.
Old Dec 3, 2007 | 01:01 AM
k2vailkid's Avatar
k2vailkid
Since you're in HotVegas, consider removing the Air Intake Heater from the Y-pipe and getting your boost reading there. Most boost gauges (I've got Autometers) come with the plug that fits the hole vacated by the AIH. If you are really into boost readings, tap into the turbo outlet part of the Y-pipe. Then you are reading true boost pressure without losses from the intercooler. Hope that helps, others will add info I've forgotten....
-Kevin
Old Dec 3, 2007 | 01:14 AM
redneckboy's Avatar
redneckboy
k well either way i need to replace the map sensor line if you delete the aih can you put it back later
Old Dec 3, 2007 | 05:12 AM
ron's power stroke's Avatar
ron's power stroke
if you keep the heater you can put it back later..here is a boost fooler with a new map line..i have this one now..when you get above 22 psi it doesnt leek the boost. he also sells the plug for the heater if you want to take it out
http://www.itpdiesel.com/store.php?crn=102&rn=280&action=show_detail
i had this one..you tap your boost into it...but when you get to 22psi it leeks the extra boost..if you want it let me know..i will send it your way
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=31
Old Dec 4, 2007 | 10:56 AM
redneckboy's Avatar
redneckboy
http://www.dieselsite.com/index.asp?...PROD&ProdID=31
Thanks I appreciate the offer. Is there a difference between the one that blows off and the one that doesnt. I have an upgraded turbo so im not worried about to much psi. To me the one that doesnt blow off is more efficent?????
Old Dec 4, 2007 | 12:19 PM
ron's power stroke
well the one that blows off would make it hard to build boost after 22 lbs and raise the EGT's trying too..it would be like a boost leak....
Old Dec 4, 2007 | 12:21 PM
redneckboy's Avatar
redneckboy
K thats what i was thinking. Ill go with the one from denis. Thanks for the help and thanks for the offer.
Old Dec 4, 2007 | 12:25 PM
ron's power stroke
your welcome..
Old Dec 4, 2007 | 01:06 PM
TN_F250's Avatar
TN_F250
Hey redneck, check out my gallery. I just took care of this, this past weekend. Boost tee is the worst solution for sure. I drilled/tapped the intake spider with a 5/16 and a 1/8 NPT tap. Not nearly as difficult as one would think. Just need to be patient and go slow as the intake is aluminum.
joeyd61
May 31, 2013 09:07 PM
mikec91
16
Apr 19, 2013 12:26 PM
jdamato1
Feb 19, 2010 10:17 AM
ford4x4956
Jul 21, 2009 10:33 AM
fbilly420
Jun 15, 2007 09:53 AM
