boost foolers?
Old Sep 19, 2007 | 01:43 PM
crack's Avatar
crack
boost foolers?
I was lookin at random PSD stuff on eBay and come accross boost foolers and some product called "BIG BOOST", wich made me wonder why no one runs a boostfooler? my budy has one on his dodge and he went from 28psi to 40-42.
does it work like that on our trucks?
Old Sep 19, 2007 | 01:51 PM
ron's power stroke's Avatar
ron's power stroke
i have a fooler...its the dial to the left with red hose going to it..after 22 to 25 PSI our trucks defuel..the fooler stops that from happening..our turbo will not build over 30lb..its the way it was built with the westgate..we have to go after market to get over 25lb of boost
Old Sep 19, 2007 | 01:57 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I have one also, look in my sig, it is called OVERBOOST ANNIHILATOR.
Old Sep 19, 2007 | 02:37 PM
Izzy351's Avatar
Izzy351
I have the ITP OBA as well -- got it as a package deal with the my Tuner from DP. Keeps the CEL from coming on (at 22-23psi), and engine from de-fueling at 25 like Ron mentioned. You can roll your own if you like and save some bucks, but some things I just prefer to get as a kit...
Joe
Old Sep 19, 2007 | 03:36 PM
WonderDonkey's Avatar
WonderDonkey
miller how does that OVERBOOST ANNIHILATOR work?
Old Sep 19, 2007 | 03:40 PM
ron's power stroke
it is what is in my picture above..there is nothing better.
this link will tell you about it
http://www.itpdiesel.com/store.php?crn=102&rn=280&action=show_detail
fbilly420's Avatar
fbilly420
It is basicly an air pressure regulator and vents extra pressure before the MAP sensor. So you can run more boost and the computer does not defuel for an over boost condition. You will not get the ses for overboost also
hope this helps.
Billy
Old Sep 19, 2007 | 03:41 PM
fbilly420's Avatar
fbilly420
Ohh i built my own with a home depot regulator and all together it cost me about 15 bucks.
Old Sep 19, 2007 | 03:45 PM
WonderDonkey
how did you build it?
Old Sep 19, 2007 | 03:55 PM
fbilly420's Avatar
fbilly420
you will need two barbed fittings to split the MAP sensor hose and install between sensor and spider. You will need to pre adjust the regulator with compressed air and adjust it to 20 to 22 psi and install.
You can fine tune the adjustment after install just increase the regulated pressure until ses comes on and then back it off a little.
Thats how I did it.
hope this helps.
Billy
Old Sep 19, 2007 | 04:08 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yep that is all there is to it. The ITP regulator looked worth $40 to me so i bought it. Those pushlok connections are sexy...
That bigboost stuff is a scam. Just like the Throttle body spacer.
Old Sep 19, 2007 | 04:17 PM
fbilly420's Avatar
fbilly420
throttle body spacer......LMAO
Old Sep 19, 2007 | 04:36 PM
bdrummonds's Avatar
bdrummonds
Look here https://www.ford-trucks.com/forums/6...st5040228.html For this and some other inexpensive mods
Old Sep 19, 2007 | 04:39 PM
fbilly420's Avatar
fbilly420
bdrummonds i thought it was you that did that awesome right up. just wasnt sure and didnt want to send anyone on a wild goose chase. AWESOME write i did the fuel gauge last weekend thanks for the write up.
Billy
Old Sep 19, 2007 | 05:10 PM
miller_feed
Just like they said up there. Here is where a real boost guage works. Reads the boost of turbo, not MAP sensor.
