What Have YOU Done To Your Truck Today?
  #10546
Old 11-20-2020, 10:34 PM
thatsrealnice's Avatar
thatsrealnice
thatsrealnice is offline
Progress
Originally Posted by thatsrealnice
What a 2nd hand hoist and some determination can accomplish.
Got old engine out today. Went pretty smooth for never having taken one out by myself before.
  #10547
Old 12-01-2020, 11:51 PM
black & blue 78/9's Avatar
black & blue 78/9
black & blue 78/9 is offline
Built my own
Short one battery to solenoid. Long solenoid to starter.
Added split loom and taped the ends to hold it in place.
Needed to change the positive cable. It was the original. Said Motorcraft (D9.....). I had some 2/0 welding cable around so I used it and made my own cables. Solder on the ends and shrink tube. Starts much better now. I forgot to take a pic of the original wire. My take one before disposing of it.
  #10548
Old 12-02-2020, 11:06 AM
Mark8man's Avatar
Mark8man
Mark8man is offline
Nice work on the cables. Quality cables with heavy copper wire like you used are not cheap if purchased outright from a quality supplier. What you'd get if bought from a big box auto supply store can't compare in quality. Win win you saved money and ended up with better cables. Installing good heavy cables are an often overlooked maintenance item on these trucks.
  #10549
Old 12-07-2020, 10:34 AM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
I have a '75 f250. During my auto to 5 speed manual swap I pulled the interior and covered the floor with sound insulation.
I also applied a layer of pad on top of that to further help with insulation against noise and temperature extremes. But, the consequence of that was that the gas pedal was prevented from reaching full throttle. That was an easy fix. I removed the pedal assembly and heated it with a torch, and bent the rod up a bit. The pedal is still comfortable to the foot, and is now able to reach full throttle with ease.
  #10550
Old 12-07-2020, 07:34 PM
thatsrealnice
Redneck paintbooth
Got a tent, propane lantern and a cooler for 80 bucks. Put my block and hoist inside tent. Propane heater, outside skin of tent 63, block 72. I turn off heater to do the painting. Then turn it back on to "bake".
  #10551
Old 12-08-2020, 03:29 PM
gvento's Avatar
gvento
gvento is offline
Hi all!
1978, f250, custom, super cab, RWD, 300 i-6, manual trans
Removed and replaced following photographed items with "upgraded" parts. Too many pictures of new parts so I made this album showing all the new parts installed.
-front and rear shocks KYB gas a just
-variable rate coil springs
-body mount bushings Energy suspension Poly
-Radius arm bushings poly
-Axle pivot bushings Poly
Unfortunately I cracked the seal on input sear shaft for my power steering gear box when i was installing body mount bushings. Rebuilding the seal and reinstalling gear box this weekend. Heading to alignment shot next week. Thanks everyone!
  #10552
Old 12-08-2020, 10:14 PM
hotrod69boss's Avatar
hotrod69boss
hotrod69boss is offline
I just finished my 93 F150 4.9c.i. auto. Finally repaired my ignition switch actuator and steering column bearings. I put on a new ignition switch- not key and tumbler. I tried to start the truck by manually moving the pin on top of ignition switch. No luck starting. Did I get a bad switch or can the truck not be started like this ? Jumped the solenoid and the truck starts right up. Mounted the new switch with no results. Bad switch or ? All ideas and information accepted. Thanks all.
  #10553
Old 12-09-2020, 01:02 AM
meangreen92's Avatar
meangreen92
meangreen92 is offline
Big hweels rollin', big hweels rollin', movin' on!
Hauled these Kenmores 20+ miles home. I stopped and put $10 in the tank, mostly so I could use their squeegee blade to clean my filthy windshield...
  #10554
Old 12-12-2020, 03:26 PM
thatsrealnice
FlowKooler
Got my water pump finally. Improved impeller design moves more cool and and anodized finish resists corrosion. Along with other parts I had powder coated, I can now begin assembling the block.
  #10555
Old 12-12-2020, 08:36 PM
Kenobi77's Avatar
Kenobi77
Kenobi77 is offline
Got new tires installed. What an improvement!
  #10556
Old 12-14-2020, 02:15 PM
Chocolatethunder's Avatar
Chocolatethunder
Chocolatethunder is offline
7th Gear
She got a bow this morning
This is chocolate thunder,
  #10557
Old 12-16-2020, 10:31 AM
EQCMCAT's Avatar
EQCMCAT
EQCMCAT is offline
Photo 1 of 2 Converted 1977 Steering Column over to 1978/79 complete with trim and turn signal switch. A shout out to forum members Rich and Twinzilla for there OEM parts help.
Photo 2 of 2 Converted 1977 Steering Column over to 1978/79 complete with trim and turn signal switch.
  #10558
Old 12-20-2020, 10:42 AM
EQCMCAT's Avatar
EQCMCAT
EQCMCAT is offline
2018 Ford Super Duty OEM Under Hood LED Light
Saturday, (19 December 2020) went to local Junk Yard to look for a pair of tweeter speakers which I got out of a loaded up 2004 Ford Expedition and they say Ford on them. Like everyone else, I looked around and saw a 2018 Ford F-350 that was t-boned on the passenger side. Checked under the hood and saw the OEM LED light, so I got that as well.
I took Ron, junk yard employee a cup of McDonald's coffee, as he lives at the junk yard in a motor home. When I was ready to leave and pay, Ron told me Merry Christmas. I send Ron a Christmas card every year ICO "Tri-County Auto Dismantler".
  #10559
Old 12-20-2020, 10:50 AM
EQCMCAT's Avatar
EQCMCAT
EQCMCAT is offline
2018 Ford F-130 Super Duty OEM LED Under Hood Light
Went to local Junk Yard Saturday, (19 December 2020) to look for a pair of tweeter speaker which I got out of a ~ 2004 loaded Ford Expedition. Then looked around and saw a 2018 Ford F-350 Super Duty that was t-boned on the passenger side. Checked under the hood and got the Ford OEM LED under hood light. Installed it in my 77 F-150.
When I was ready to leave and pay, Ron (junk yard employee) told me "Merry Christmas". I know Ron lives at the Junk Yard in his motor home, so I took him a cup of McDonald's coffee, which he said it was really good, and I send Ron a Christmas card every year, ICO "Tri-County Auto Dismantlers".
  #10560
Old 12-20-2020, 12:44 PM
thatsrealnice
LED
I'm going to have to remember that about LED hood light. Yeesh. What a place to live. That was nice of you with the coffee and the card. A friend of mine used to send a card to his favorite bar, and Margaret. The lady that was there so often and so long, that you wondered if she did not in fact live somewhere inside the bar.
Quick Reply: What Have YOU Done To Your Truck Today?
