changing over to hei
Old Feb 8, 2010 | 07:34 PM
codyh77's Avatar
codyh77
I have 69 f250 high boy that im trying to change over to hei. I could use all the help i can get on doing so. I have the hei distribtor for a 74 and an control module box for it as well. Just could use sum help runing wires and needing to know if i need to change out the ignition switch. Thanks for looking and thanks in advance for the help.
Old Feb 8, 2010 | 08:01 PM
Ford_Six's Avatar
Ford_Six
Use the factory wire to the coil to actuate a relay, and then use the relay to power the ignition module. Run a wire straight from the battery to the relay, with a 30a fuse as close to the battery as you can get it. You should put a ballast resistor after the relay, but I've run the DSII modules of straight 12v with an e-coil with no ill effects.
Ford never used an HEI system, that was GM. Ford called their electronic ignition Duraspark.
Old Feb 8, 2010 | 10:43 PM
codyh77's Avatar
codyh77
thanks
Sounds easy enough thanks for the info.
Old Feb 9, 2010 | 10:39 AM
bmuhlbach's Avatar
bmuhlbach
Welcome to the site.Search the forums this has been asked before and ther is some good diagrams
Old Feb 16, 2010 | 08:10 PM
lance65's Avatar
lance65
here ya go...
Old Feb 17, 2010 | 09:49 AM
lance65's Avatar
lance65
or you can follow this....www.junkyardgenius.com/<wbr>ignition/jeep/<wbr>HEIcompair.html - Cached
Especially if you are tired of changing out those foreign modules. Enjoy!
-Lance
tjdad62
Dec 28, 2014 06:01 AM
65fordf100iowa
Sep 2, 2010 08:25 AM
cujo8
19
May 31, 2010 07:53 AM
marcsmithracing
Dec 1, 2009 10:02 AM
Micginish
Electrical Systems/Wiring
Jul 18, 2004 03:15 PM
