Procomp Distributors?
Old May 27, 2006 | 07:45 PM
cujo8's Avatar
cujo8
I have been looking to replace my stock Duraspark ignition system with a ProComp Distributor. They offer both an HEI and non-HEI diistributor and I am wondering if anyone had used these distributors before and had any recommendations? The non-HEI needs an external coil and I do have a new stock-style Accel race coil to use with it if I go that route. Thanks.
Jim
Old May 28, 2006 | 05:45 AM
ken75ranger's Avatar
ken75ranger
I know a few guys that run the HEI with no problems. Just make sure the gear is compatible with your cam.
Old May 28, 2006 | 07:30 PM
cujo8's Avatar
cujo8
So has anyone here run these ProComp distributors? They seem to be quite reasonably priced, but I have not heard of them before. Thanks.
Jim
Old May 30, 2006 | 12:21 PM
83-351cj's Avatar
83-351cj
I am running a billet PRO-COMP distributer and a PRO-COMP 6AL box. These parts are made by MSD. They are just private labeled.
Old Jul 9, 2009 | 11:07 AM
kwolfe97's Avatar
kwolfe97
I bought one (procomp distributor) on ebay very reasonably priced and put it in my 80 351w truck. It runs 15-20 minutes after sitting cold and quits due to losing ground to the black wire suddenly while running. It will restart after x amount of time after cooling I guess....I am not sure the distributor the problem but it this is driving me crazy.
Old Jul 9, 2009 | 11:31 AM
IntheTrees's Avatar
IntheTrees
I was looking at the Procomp Distributors too, but after a little research it sounds like they are pretty poor quality. I decided to stick with the Duraspark.
Do a google search and you will see lots of forum threads where people have had problems with them.
Old Jul 9, 2009 | 05:06 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
X2 Bad rep. Hard to beat the Duraspark for price. Plus you can work wonders recurving it.
Old Jul 12, 2009 | 01:46 AM
86bigred's Avatar
86bigred
here is an idea
http://www.carbdford.com/tech/HEI/hei.htm
Old Jul 13, 2009 | 10:08 AM
clgreer's Avatar
clgreer
interseting concept, i wonder how well it works, i think ive replaced my control box 5 times now, would be nice to get rid of it all together.
Old Jul 13, 2009 | 10:43 AM
IntheTrees's Avatar
IntheTrees
Yeah, I've seen that article before and considered doing that.
But, is the HEI module really any better than the Duraspark?
To me, the main advantage of an HEI distributor is that the coil and module are contained inside the cap for a cleaner engine bay.
You wouldn't get that with jus the module conversion.
Old Jul 13, 2009 | 04:11 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Jim
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/...d_351W_V8.html
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Jul 13, 2009 | 07:56 PM
dinosaurfan's Avatar
dinosaurfan
Smile dizzies
CujoJim, keep the duraspark. The duraspark really is the best distributor a Ford V8 can have. Money spent on a 'high performance' distributor is a waste. There really isn't any such thing. If you want to increase ignition power, keep the Duraspark dizzy, but use it to trigger an MSD or accel or jacobs or whomever else you like. When you want more performance, the dizzy will need to be recalibrated. An HEI won't help, they're intended for a chevy, and they have heat problems with the module inside the closed housing. AND they're funny looking. You can reshape the curve in your dizzy all by yourself, but not everyone likes playing with such things. And if the bushings in your dizzy are worn, the spark will wander all over the place. You CAN replace the bushings, but they are a pain to get. If you get a new duraspark from somebody like perfdist, they will put one together with the beefier bushings and curve it however you want. Drop it into your engine, plug it into your controlbox/amplifier of choice and your troubles are over. DinosaurFan
Old Jul 13, 2009 | 08:07 PM
fordeverpower's Avatar
fordeverpower
df, i agree about keeping the dizzy and using a msd box. Procomp is chinese and not made by msd, the chinese ripoff products, like edelbrock heads, intakes,etc
Old Jul 15, 2009 | 05:41 AM
leesflare's Avatar
leesflare
Well, Dino, not to rain on your parade, but having run a D.U.I. HEI unit in my 351w for about 10 years, I can personally vouch for their quality and longevity. Being a GM tech since '92, the "usual" HEI failures were those caused by wannabe mechanics who failed to put the heat transfer grease between the module and the distributer housing, or those that refused to do a tune-up for 100k miles, with the ozone build-up inside the cap causing terminal pin corrosion from the pick-up coil to the module. Yes, the modules do get hot and do require a proper heatsink to pull off that heat, so just bolting a module to the inner fender to run your Duraspark dizzy will cause a quick demise and further the GM quick failure myth
Concerning the Duraspark dizzy, I have a unit from a '85 Mustang GT that has been modified using the info from carbdford, that is wired to a GM module. I have this in my 302 in a '60 Falcon. As soon as Photobucket comes back on-line (down for maint.) I'll post some pic's, along with a shot of a neat heatsink that GM mounts their external modules to, on the 4.3 Blazers. Not expensive, either (about $15.00)
Lee
Old Jul 15, 2009 | 03:06 PM
leesflare's Avatar
leesflare
Ok, as promised, some pics;
D.U.I. HEI in my 351w
Duraspark dizzy w/GM module in my Falcon
Module and heat sink
Lee
