Single Shot Injector Question?
Old Feb 7, 2010 | 04:48 PM
  #46
01 EXCURSION MORRIS's Avatar
01 EXCURSION MORRIS
I'M THINKING ABOUT SINGLE SHOTS ALSO
ONE OF THE ORIGINAL QUESTIONS WAS STAGE 1 OR STAGE 2 (SINGLES)
I HAVE JODY'S 120/140
COLD AIR
4 INCH
SEEMS THE STAGE1 IS ONLY ABOUT 50 HP.
STAGE 2 90HP OR SO?
I PLAN ON UPGRADING TURBO/FUEL SYSTEM EVENTUALLY.
DO YOU THINK STAGE 1 IS A WAIST.
I'M GUILTY LIKE MOST I'LL WANT MORE.
CAN I GET AWAY WITH STAGE 2 TILL I DO OTHER UPGRADES?
IF I KEEP OUT OF THROTTLE SAY UNDER 2800 RPM (GOING UP TO 2800RPM,BACKING OFF CAN I GET AWAY WITH EGT ISSUES ETC.
THANKS
Old Feb 7, 2010 | 07:47 PM
  #47
01 EXCURSION MORRIS
I found the thread with all the answeres futher down the line.
Thanks for all the info.
I'm in the process of going through that thread.
Old Feb 7, 2010 | 07:56 PM
  #48
big poppa's Avatar
big poppa
Hey 01, beings its Sunday, not alot of traffic but its picking up, this thread will get you the answers you'll need if you haven't gotten them already, hang around. I have a certain preference for hybrids but I'm learning the benefits of all size injectors..
Old Feb 7, 2010 | 07:58 PM
  #49
megawatt00's Avatar
megawatt00
COLD AIR
4 INCH
STAGE 2 90HP OR SO?
THANKS
I have Jody's tunes with Stage 1's cold air intake 4 " turbo back into stacks and a 38R My truck cranks with this set up and it is a dually. Yesterday I spun the tires on dry pavement in the 80E tune from a dead stop.
Old Feb 7, 2010 | 11:21 PM
  #50
Pocket's Avatar
Pocket
Originally Posted by ernesteugene
So what I'll do instead is add a few more words to the topic of engine wear versus single-shot and split-shot injectors! The "pilot injection" feature of the newer split-shot injectors reduces the "ignition delay" for the "main injection" that follows ...and this in turn reduces both ...the rate of increase in cylinder pressure and temperature ...and the maximum values of cylinder pressure and temperature in the vicinity of TDC.
With single-shot injectors the extra fuel mass that's initially injected causes a longer "ignition delay" and in addition to the adverse impact this has on cylinder pressure and temperature ...a longer "ignition delay" also means there's a greater chance for some unburned fuel to contact the cylinder wall and find its way down past the piston rings ...thereby causing an additional disruption to the oil film between the rings and the cylinder wall!
Well, since cylinder pressure testing already exists, we can see if there is actually a problem. However, those who do CP testing haven't issued any warning about singles yet, so there doesn't seem to be an issue to begin with.
In addition, many stock 7.3L PSD's came equipped with singles, and that hasn't affected longevity of those engines either.
Old Feb 8, 2010 | 08:46 AM
  #51
01 EXCURSION MORRIS
BIG POPPA,
based on your signature it appears injectors is your next step.
I spoke to Clay he indicated I could go stage 1 and upgrade to stage 2 later for around $600.
I didn't ask if he could turn the stage 1's into Hybrid's?
Old Feb 8, 2010 | 10:59 AM
  #52
RussB's Avatar
RussB
Jim is your truck a auto ??????
Old Feb 8, 2010 | 11:33 AM
  #53
01 EXCURSION MORRIS
Jim,
Who's singles do you have?
What power level do you run it in (when your into throttle)
Egt issues?
Fuel economy in 80e tune?
Old Feb 8, 2010 | 01:57 PM
  #54
01 EXCURSION MORRIS
Jim,
Are your running stock fuel pump?
Any mods to lines in the fuel tank. (hutch)
Thanks
Tim
Old Feb 8, 2010 | 02:08 PM
  #55
farmb0y's Avatar
farmb0y
Gene, you're confusing me here. I'm reading this and I see it going both ways. Hopefully I can word it clearing enough to ask my confusion.
With single-shot injectors, you say they have a longer ignition delay, causing a greater chance of cylinder washing. Isn't that all controlled by SOI, which any tuner can malnipulate? Can't they delay the injection so that it optimizes the combustion event?
Also, If fuel "sitting" in the cylinder before it ignites is bad and can cause washing, how then is a pilot shot better, since it sits there longer before the fuel/air is compressed enough to ignite?
Old Feb 9, 2010 | 04:15 PM
  #56
ernesteugene's Avatar
ernesteugene
Originally Posted by farmb0y
...Gene, you're confusing me here. I'm reading this and I see it going both ways. Hopefully I can word it clearing enough to ask my confusion.
Also, If fuel "sitting" in the cylinder before it ignites is bad and can cause washing, how then is a pilot shot better, since it sits there longer before the fuel/air is compressed enough to ignite?.
I should've known that giving a partial answer would lead to more confusion than giving no answer at all ...but I thought the OP deserved to get the word about the adverse consequences before rather than after he installed single-shots!
As I've already said I'll be giving a more complete answer here... https://www.ford-trucks.com/forums/9...tock-7-3l.html ...but only after I've done the background posts leading up to the several I'll be giving on injectors!
Old Feb 9, 2010 | 04:31 PM
  #57
big poppa's Avatar
big poppa
BIG POPPA,
I wish I could help you on which ones can be swapped, disasembled, I'm learning hear as well, I'm also trying to educate myself as too which ones. I will say this, do it once and do it the way you want it IMO unless you like pulling injectors, which I never did.
Old Feb 9, 2010 | 05:53 PM
  #58
01 EXCURSION MORRIS
Thanks for the reply
I'm sure we will find the correct path,based on the feed back from the ones who have gone down that path before us.
Looking forward to the input.
Old Feb 9, 2010 | 06:01 PM
  #59
big poppa's Avatar
big poppa
Anytime, me too, grab some popcorn..
Old Feb 9, 2010 | 07:30 PM
  #60
Izzy351's Avatar
Izzy351
Yes, you can turn a single into a hybrid. In fact, that what a "hybrid" is! Mine are AA code singles with B-code (DT530 injector) guts.
