99 Expedition Windshield must replace Is it True
Old Feb 2, 2010 | 02:16 PM
hgufrin's Avatar
hgufrin
Called the local Autoglass repair center to ask if they'd fix my 99 Expedition windshield leak. He said that they would ONLY replace the ENTIRE windshield.
The reason: he said that this year (and 2000) has a windshield that has a coating (black) around the edges that is the source of the leak. He said the ceramic separates from the glass and that a simple reseal would not cure the problem.
Truth or fiction?
Old Feb 2, 2010 | 02:25 PM
alloro's Avatar
alloro
I think it was just last week that someone said that same thing here, or was that you?
Old Feb 2, 2010 | 02:27 PM
alwaysfords41's Avatar
alwaysfords41
I've heard that before. I've also heard of people having luck with Silly-Cone under the weatherstrip. I'd make sure I had glass replacement coverage and drive behind a gravel truck.
hgufrin's Avatar
hgufrin
i believe i said it on my other post but didnt get a reply. like to hear some input before i tell them to go fly a kite
Old Feb 2, 2010 | 04:04 PM
alloro's Avatar
alloro
Check with another glass place and see what they say.
Old Feb 2, 2010 | 10:23 PM
Moto Mel's Avatar
Moto Mel
What he said!
It is not too hard to reseal the bottom and sides of your windshield as a temorary fix but the glass should really come out to do it right. Most likely they told you that because they usually break the glass when trying to remove it or it just takes too much time for the money they can charge.
If you do try to reseal it your self you should try to get the same sealer the glass shops use as the standard silicone can be caustic and start corrosion where it touches bare metal.
There are many types of silicone sealer out there.
Old Feb 3, 2010 | 02:13 PM
ArgoExpedition's Avatar
ArgoExpedition
Originally Posted by Moto Mel
What he said!
And be sure to clean the area where you suspect the leak to be really good before applying any sealant. I usually use liberal amounts of rubbing alcohol and cover well past the area I suspect as leaking. Approximately $5 in supplies to do it yourself, so well worth trying.
Old Feb 3, 2010 | 04:40 PM
alloro's Avatar
alloro
I picked up a tip from someone on this site for help in finding the leak. Close all windows and doors, turn the blower on high, turn the **** to vents. (Don't use MAX A/C.) Now use a spray bottle with a soapy water solution and spray around the windshield. The blower is building up pressure inside the vehicle so the air will come out any place it can. You will see bubbles where the windshield leak is.
Old Feb 4, 2010 | 01:22 PM
fasttruck9's Avatar
fasttruck9
DIY
Hey Guys, I had the leaking on the drivers side grab bar, it didn't have anything to do w/sunroof. It was the famous leaking windshield. Found my leak by spraying the top of windshield w/soapy water, closed all windows and turned on front/rear blowers on high, eventually you will see the leak where the bubbles show up. My leak was about five inches to the right of the rear view mirror (towards the drivers side A-post). It's not a bad diy job, pulled the top seal, cleaned as well as I could across the whole top of winshield, and sealed the channel with a product from state chemical called perma-seal, but I think a 100% silacone will work, replaced rubber seal. This worked great, hope this helps!
I thank this forum where I found the above information, as I too thought it was my sunroof.
75BigBlock
Idaho Chapter
Oct 7, 2017 05:41 AM
Ron94150
2015 - 2020 F150
May 31, 2017 07:06 AM
Gage2502
Apr 10, 2014 03:42 PM
81-F-150-Explorer
Nov 4, 2011 08:33 PM
rjd75
Jun 29, 2007 11:31 AM
