getting new batteries
Old Jan 22, 2010 | 03:51 PM
smokersteve's Avatar
smokersteve
Motorcraft has them for about $100.
I am interested in getting optima. Yellow??
How much are they?
Thanks
Old Jan 23, 2010 | 02:12 AM
Headviking's Avatar
Headviking
Whatever you do allways replace in pairs.
Old Jan 23, 2010 | 10:06 AM
texans's Avatar
texans
Just stick with the motorcraft. they have a good history and seem to last a long time. the optimas that I have seen have been upwards of $220 or so. I dont think I would want to buy two of those. and yes be sure and replace both batteries at the same time. no matter if only 1 reads bad or not.
Old Jan 23, 2010 | 10:29 AM
smokersteve
Thanks, im planning on getting 2.
Thanks for the help, I will get motorcraft. is $105.95 reasonable??
Old Jan 23, 2010 | 10:58 AM
william_04_x's Avatar
william_04_x
that's a decent price if you're looking at the 850CCA, not the 750's.. I've only replaced my batteries once since the truck was new, and I stayed with Motorcrafts.. No regrets..
Old Jan 23, 2010 | 12:38 PM
rocky1074's Avatar
rocky1074
I got a price at my dealer,,,125.00 for 750 & 135.00 for 850..
Old Jan 23, 2010 | 02:00 PM
ljutic ss's Avatar
ljutic ss
I picked 2 Motorcraft BXT 65 850 CCA's on Jan.4th. for $106.20 they list for $124.95
Old Jan 23, 2010 | 03:24 PM
fordmasterdieseltech's Avatar
I recommend motorcraft as they last a while and have a good prorated warranty.
Old Jan 23, 2010 | 07:25 PM
sandmanf250's Avatar
sandmanf250
still got the original motorcrafts in my 03- 6.0.164,000 and it still whips her right over. definetly will use them when time for a change.
Old Jan 23, 2010 | 07:37 PM
dschuffert's Avatar
dschuffert
Motorcraft are good batteries. I like DieHard Platinum's or Interstate. My Motorcraft's, that came with the truck, lasted about 3.5 years before I had to replace them. I ended up buying the DieHard Platinum P2's. They are AGM, on the expensive side - $180 each, and 950 CCA each. I liked the four year total replacement warranty along with another four years of pro-rating. I have had them a little over a year, and so far, so good.
Old Jan 25, 2010 | 11:41 PM
theonlypheonix's Avatar
theonlypheonix
I would second the DieHard AGM Platinum P2's, while I've had the OEM Motorcraft since new ( now 4 1/2 year) they have become tired after last winters -34 temps. I've used Walmart Everstart brand in the past in my other autos and had good luck with them. Currently I have one that is 6 years old in my 95 Olds 3.8L and it started fine last year at -34. But for starting a diesel in the dead of winter I would recommend the AGM batteries. They will crank the engine at a higher RPM ( slightly higher voltage but more capacity then flooded cell technology). Noticably faster cranking RPM then either the Motorcraft or Everstart batteries( almost sounds like you were cranking the engine without the glow plugs in).
Had the AGM now 2 months and no complaints with them so far ( other then the initial cost). The AGM technology in general terms is better then the flooded cell or gel cell and also you can get higher capacity battery then the gel cell technology.
If one lives in the southern climates mostly likely any battery will work fine, but if one lives in the northern climates where it can get cold one should consider a higher capacity battery and right now that seems to be AGM TECHNOLOGY.
Old Jan 26, 2010 | 12:15 AM
BigRy's Avatar
BigRy
Yeah, I got the Optima Yellow, List is 229.00. I get them for 140.00 a piece. They have a great warranty, and the fact that they are a sealed battery. But If I didnt have my hookup at Optima, I would be going for the Motorcraft batts myself.
Old Jan 26, 2010 | 12:50 AM
cartmanea's Avatar
cartmanea
I would go with Interstate or Motorcraft, Optimas are over-priced unless you do a lot of high angle offroading.
B_Allen
Oct 10, 2013 04:54 PM
stbrem
New Hampshire Chapter
154
Mar 20, 2006 06:19 PM
jagabom
Garage & Workshop
21
May 25, 2003 08:00 PM
Hottarod
Feb 27, 2002 11:43 AM
beratte
1978 - 1996 Big Bronco
May 18, 2001 07:30 PM
