I have a '73F-350 4spd Std 360 V-8 the engine I installed is from a '77 Merc. 460 V-8 4bbl. I got the conversion kit from Advance Adpaters, also changed the engine perches on the chassis for '79 model.I got a bellhousing that matches the 460.
Everything Bolts OK,--BUT the fork can't move,the
pressure plate is up pushing the fork towards the tranny.Whats wrong pressure plate,flywheel,fork..?
I am not really an expert at this but here is my 2 cents. If you used the pressure plate/clutch from the 360FE I think that may be the problem . I dont believe they are interchangeable between FE's and the 460's.
If I am wrong I am sure I will be corrected Good luck and hope you get a better answer
> If I am wrong I
>get a better answer
>4bbl.
>the 460. Everything Bolts OK,--BUT the
>fork can't move,the pressure plate
The tranny is the original '73 4spd.
If it's the Clucth Kit do you know which one
will fit?
FE stands for Ford Edisel. It is a family of Ford big block engines. A few of then are 352, 360, 390, 428. Since you said you previously had a 360 V8 you must have had an FE engine.
Most FE parts only will interchange with other FE engines. Hence when you swapped to a 460, different class/family of engine, the old tranny bell housing wouldnt bolt up. I am unsure about the clutch, pressure plate and flywheel but I would guess that they are different.
Once again just my thoughts. I am sure about the differences between the FE's and the 460 engines. just not 100% sure about the differences between the clutches etc.
Hope this helps some
>an FE engine. Most FE
>they are different. Once again
>the clutches etc. Hope this
>helps some
Thanks , this week I will take it apart,
I will test diferent Clutch set up's
I will let you know what happens.
