Clutch fork return spring
Old Oct 18, 2012 | 01:35 PM
bigdan1979f-250's Avatar
bigdan1979f-250
Hey I just swapped a 460/T-18 into my 79 f-250. My old clutch return spring that goes from the clutch fork to the motor perch and keeps the throwout bearing off the pressure plate fingers is shot and I need a new one. Anyone know where to get a new one or know of something else that will work?
Old Oct 18, 2012 | 04:27 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Most parts stores have a "universal" clutch spring you should be able to use. LMC has one, P/N 40-3201 14" long $10.95. You can probably get a similar spring locally, cheaper.
From your description, it sounds like the one you had was hooked up wrong. The front of the springs hooks to a bracket on the frame rail, not the mount perch.
Old Oct 18, 2012 | 05:27 PM
psquare7575's Avatar
psquare7575
The parts truck (79 F350 2wd) had the spring hooked to the mount perch as well. I bought an NOS spring and it was both shorter and softer.
Old Oct 18, 2012 | 05:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I just went back and looked at the diagram and I may be wrong . The setup I was thinking of is shown for the F150/250 4WD (detail A). It's not real clear, but it looks like the spring does at least hook to the crossmember or perch.
Old Oct 18, 2012 | 06:28 PM
NBC-Steve's Avatar
NBC-Steve
I broke my spring a couple of years ago and I just went to my local hardware store and picked one up that was the same size for a few bucks (Plus a spare). It's still in use today and works great.
woodhd
27
Nov 25, 2024 02:53 PM
sonny1965
Jun 8, 2014 05:33 AM
NBC-Steve
Aug 23, 2010 09:36 AM
dspeer75
May 5, 2009 08:04 PM
DAV1972
Mar 5, 2001 08:53 PM
