360 clutch issue
my brother called me this morning from Colorado(I'm in Ohio), he has a old 460 dumptruck that threw a rod a couple years ago, just put a good running 360 FE with bellhousing/fork(no clutch) someone gave him - he got a FE clutch/pressure plate, fabbed a new mechanical clutch linkage, to replace the hydraulic one, got the mounts/everything in- said it was a bear- but the clutch wont disengage...he wont touch a computer, so suggesting he get on some forums was to no avail- thought I'd ask in his place
he said he can see the pressure plate back off the friction surface when the clutch it pushed, but its still driving/wont disengage, so I told him I think he's just got the wrong clutch disk/flywheel clearance, but guessing a hodgepodge of parts over the phone is not very effective
He did say the pressure plate he bought was the diaphragm type with the 'fingers' all the way around- I'd always thought most truck applications were the 3 armed 'long' or 'borg-beck' style pressure plates?
Anyways, wondered if anyone out there has done a similar swap and if they might have a part number or even just application year/model that might have came with a mechanical linkage/360 so he can see what the right clutch should be for that flywheel... sorry- know its not much info, but figured there should only be one or two truck applications for a manual transmission/360 over the years...also, a general FE question- did the 352/360/361/390/427/428 use different flywheels? I would assume so, just wondered if any others might share the same diameter/balance in searching for alternate clutch availability...
thanks in advance for any info
Tim
* also shoulda mentioned I asked if he might have flipped the disc, he said it only fit the pressure plate one way (?)
so tomorrow he'll be off to find a disc that matches the original- still not sure what model truck the 360 came from, so might just need to have the parts store folks look at a few... those guys hate that
i helped break a old clutch on a tractor loose many years ago, think I was still in highschool... an old international harvester h or m- the trike wheeled one- we tugged that thing back and forth a bunch, wouldnt bust loose- ended up push starting it in gear and driving around a while- eventually vibration/torque shook it loose...seemed impossible that a little rust could hold so tight... never forget that day, raking hay, dropped the front wheels into a groundhog hole, nearly flipped the thing...popped straight up in the air, bent the hitch/rake, muffler flew off right over my head- those skinny steering wheels are hard to hold onto when hangin on for your life
Anyways...
