62 4x4 Powersteering
Old Oct 2, 2017 | 11:31 PM
garbz2's Avatar
garbz2
Same modifications needed on the drag link for the two wheel drive as the four wheel drive.
Garbz
Old Oct 3, 2017 | 12:30 AM
A_sharp#eh?'s Avatar
A_sharp#eh?
Thanks Garbz. I hope I have everything I’ll need. I can post a parts list when it arrives.
Old Oct 4, 2017 | 07:41 AM
1972RedNeck's Avatar
1972RedNeck
Signed on for the results...
Old Nov 30, 2019 | 04:58 PM
A_sharp#eh?
So I got the power steering in finally the thing works but it blocks the clutch linkage—-fail. So I got a hydraulic clutch and am in the middle of drilling through the clutch fork which is the hardest steel on the planet!! And like and inch and a half thick so more on that later.....
Old Dec 1, 2019 | 02:33 AM
Thunderkiss1965's Avatar
Thunderkiss1965
Many hours later...
Old Dec 1, 2019 | 08:12 AM
Kurtboyd's Avatar
Kurtboyd
What I did in 2013.
PS Conversion
Old Dec 1, 2019 | 09:17 AM
2dwoods's Avatar
2dwoods
Working on my Sami right now but when done im going power on my 65 I already have a Dana 60 and steering gear box and all other parts off a 79 f350 4wd .I am running a 351w so I got a pump and mount from a econoline which have the same good pump like a Chevy I think there stronger pumps and the only thing they had better than Ford period
Old Dec 1, 2019 | 10:48 AM
A_sharp#eh?
Originally Posted by Thunderkiss1965
Many hours later...
yep, that and forgot about this thread lol. I deployed and didn’t have the correct parts I had to re drill holes for the proper angle for the p/s box the placement of the holes from the manual box was so far out of the way and not possible to connect the steering column so not to make the frame Swiss cheese I had to weld a sheet of steel on there and then drill the holes and get all sorts of new fittings did the brake booster as well and have been working on the clutch fork for a while now too.
Old Dec 1, 2019 | 12:20 PM
2dwoods's Avatar
2dwoods
I put a hydo clutch in mine but since I have upgraded my trans to a t19 it already had one . I can tell you this when mounting master cyl. I got my mounting holes just a hair off and I mean a hair and the push rod to pedal seal goes out from time to time from ware
Old Dec 1, 2019 | 09:07 PM
wcs69rat's Avatar
wcs69rat
I just posted a thread on this. EZsteer makes a bolt in kit now that includes the steering box, Saginaw pump, pump mounting bracket, hoses, U-joints, intermediate shaft, and lower column support. I'm going that route. I know there are other methods that may be a little cheaper but that lower initial cost has a way of creeping up by the time you are actually finished. You can get the mounting bracket for whatever engine you have (mine is a 351W). I also had them swap out the single groove pump pulley for an serpentine pulley since my engine has a serpentine set up. I'll update my original post on how the installation goes. The only issue that EZsteer said I may have is clearance between the new steering box and the headers. However, I have a block hugger style header and the rear primary tubes actually run forward so my stock steering box is actually located aft and below the headers. Hopefully it all works out.
https://www.ebay.com/itm/61-62-63-64-Ford-F-100-F-250-Power-Steering-Conversion-Kit/123922723849?_trkparms=aid%3D111001%26algo%3DREC.S EED%26ao%3D1%26asc%3D20160908105057%26meid%3D069e8 c1b3f1549259f7c3f1bb5a06037%26pid%3D100675%26rk%3D 1%26rkt%3D15%26sd%3D123922723849%26itm%3D123922723 849%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p23 80057.c100675.m4236&_trkparms=pageci%3A8317ac07-0c13-11ea-8837-74dbd1807992%7Cparentrq%3A8c1eb55e16e0ac3d5d1a0744 ffea2d50%7Ciid%3A1
The kit is listed at $895 plus $45 shipping. He told me he would do like $850 plus $45 shipping but on black Friday I got an offer from him for $795 plus shipping so I did that.
This is not the exact kit but very similar. I believe this is the 1948 to 1950 something kit
Old Apr 13, 2020 | 03:43 PM
RustyPhil's Avatar
RustyPhil
Originally Posted by Kurtboyd
What I did in 2013.
PS Conversion
Hi,
I just read your posts of 2013 of your ps conversion project. I got hold of a 1962 F250 4x4 a few months ago here in Sweden and
I really would like power steering on it.
It would be nice with a hydraulic ps like you used. Do you have any experience with an electrical one like the EPAS?
Best regards,
Philip
Buford
May 11, 2013 08:13 PM
mwsF250
Modular V10 (6.8l)
Mar 29, 2011 08:20 AM
army8t1
Aug 9, 2007 08:56 PM
mav4804
16
Oct 9, 2003 01:00 PM
