help!!!!!
Old Jan 5, 2010 | 02:25 PM
  #31
wreckinball's Avatar
wreckinball
my money was on a 1986 f250 6.9l. "shakes magic 8 ball" hmmmmmm let me see ah yes, "ask again later" hahaha
Old Jan 5, 2010 | 04:26 PM
  #32
Rick Wallace's Avatar
Rick Wallace
Drop back and punt..............
Old Jan 5, 2010 | 04:32 PM
  #33
starmilt's Avatar
starmilt
Just recently Dave posted a picture of the relay with that wire circled if any body knows what thread it was. it has been in the last three or four days.
Old Jan 5, 2010 | 06:46 PM
  #34
starmilt's Avatar
starmilt
Bump for biggotis look at the picture of the relay then scroll down to Daves post and read then tell us what else you need.
Old Jan 5, 2010 | 06:52 PM
  #35
starmilt's Avatar
starmilt
Ok I bumped your other post up check it out and get back to us with what you don't understand.
Old Jan 5, 2010 | 07:57 PM
  #36
starmilt's Avatar
starmilt
This would be easier on the other thread.
Old Jan 6, 2010 | 12:45 PM
  #37
starmilt's Avatar
starmilt
Ok the reason that it would be easier on the other thread is one that is where the pictures are and where Dave gave the instructions on what to check. It would be easier than bouncing back and forth thats all. You have eliminated the fuse links at the relay. Have you checked the connector on the inner fender that is in the first picture and Dave explained is going to be different colors but is still there and a common cause for your problem.
Old Jan 6, 2010 | 01:14 PM
  #38
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by bigottis1986
Ok guys i took a test light and it showed the fusible link is ok, I hooked clip to plug part of wire and probed into the wire under the link and light lit up. Ive checked fuses and there good only thing left is relays and i dont know how to check them, also need to check the grounds maybe i need to clean the grounds at engine block and frame??
well,this should be done every once in a while anyway.so id do it yeah.(first thing i would have done.)
good batteries and clean wires/connections are a must.
Old Jan 6, 2010 | 09:23 PM
  #39
Dave Sponaugle's Avatar
Dave Sponaugle
I will merge them into one.
mrad
Modular V10 (6.8l)
Apr 19, 2012 09:56 AM
alanscott
Aug 12, 2002 02:26 PM
disappointed
Mar 26, 2002 03:40 PM
beratte
1978 - 1996 Big Bronco
Feb 15, 2002 02:14 AM
cyberbyrd
Feb 3, 2002 04:42 PM
