I have heard that some Ford mechanics state that gapping the plugs at .055 instead of .044 help with the engine in mileage and power. Can anyone confirm this? Has anyone really tried this cheap mod?
Also, I know that playing with the timing can produce different mileage and power values. Has anyone adjusted the timing from the Ford spec and seen an improvement? If so, where did you set the timing? It seems that from speaking with some mechanic friends, I should play with the timing as I live in Denver, which equals high altitude and less power.
When I installed the MSD 6A box, Coil, and NGK plugs gapped to .055", my HC (unburnt fuel) reading was actually lower than my 93 Civic, so I think that it should help out with the gas mileage as long as there are no misfires.
>Whats involved with those high altitude packages that
>vehicles are equipped with in these mile high places? Must
>invlove some these things, dont they?
According to one of my Ford emissions books,it is noted that High Altitude specs has a reference point of about 5000ft above sea level.
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
I asked a guy thats been working on Fords for over 20 years. What would help my mileage most. He said to gap plugs at 54. My truck is all stock, I'm also in N.C.
Opening the sparkplug gaps up work fine, as long as this dosen't cause misfires. If it does, then an aftermarket coil is needed. Most of the MSD, Jacobs, Mallory, etc, put out around 40-50Kv. This is plenty of voltage to fire a gap of .050-055". Low resistance sparkplug wires will also allow for a wider gap.
Adding a better coil and wires is the best/cheapest ignition upgrade you can do, IMHO...
I think that the stock unit might be able to handle .054 but you may not have any margin left for electrode wear and increased demand of high RPM operation. Remember that larger gaps require higher voltage to fire and higher voltage wears down the spark plugs faster. I'd say give it a try using copper plugs as copper is a better conductor than platinum
