Just recently Dave posted a picture of the relay with that wire circled if any body knows what thread it was. it has been in the last three or four days.
Ok the reason that it would be easier on the other thread is one that is where the pictures are and where Dave gave the instructions on what to check. It would be easier than bouncing back and forth thats all. You have eliminated the fuse links at the relay. Have you checked the connector on the inner fender that is in the first picture and Dave explained is going to be different colors but is still there and a common cause for your problem.
Ok guys i took a test light and it showed the fusible link is ok, I hooked clip to plug part of wire and probed into the wire under the link and light lit up. Ive checked fuses and there good only thing left is relays and i dont know how to check them, also need to check the grounds maybe i need to clean the grounds at engine block and frame??
well,this should be done every once in a while anyway.so id do it yeah.(first thing i would have done.)
good batteries and clean wires/connections are a must.
