F100 lowering question
Old Dec 29, 2009 | 04:35 PM
mwvdub's Avatar
mwvdub
picture of the tie rod relocator.
Old Dec 30, 2009 | 01:31 PM
b_duncan's Avatar
b_duncan
mwvdub,
Thanks for the picture; very helpful! Where did you get your springs from?
Old Dec 30, 2009 | 02:27 PM
mwvdub's Avatar
mwvdub
Just stock springs with a fresh coat of paint. The rest of the frame looks terrible but the springs turned out nice.
Old Feb 27, 2010 | 09:44 PM
b_duncan's Avatar
b_duncan
Here are some updated pics. The front was lowered four inches by using DJM ibeams and cuttings a turn off the coil. The rear was lowered Five inches using an axle flip kit.
Old Feb 27, 2010 | 09:47 PM
b_duncan's Avatar
b_duncan
Ill be getting the body ready to paint within the next month..Ill post pics when I get started. The roll pan is installed, just have to weld it in.
Old Feb 27, 2010 | 11:53 PM
f100 freak's Avatar
f100 freak
looks good, are those stock ford rims on it? the are the ones I want if I cant find some origional lightning rims for mine,
Old Mar 1, 2010 | 12:05 AM
b_duncan's Avatar
b_duncan
Yes, they are stock ford wheels. They will on only be on the truck for a short period of time while I am doing the body work. Ill be using 20s or possibly 22s soon.
Old Mar 4, 2010 | 11:59 PM
modularF100's Avatar
modularF100
Beautiful progress! I'll be doing the same thing sooner or later, how's the alignment with the chopped springs? Did you have to c-notch your frame?
Old Mar 5, 2010 | 08:59 PM
b_duncan's Avatar
b_duncan
The flip kit I purchased did come with the C-notch, but however I did not see the need to use it. After flipping the axle I have about 5 to 6 inches of space between the axle and frame. I do not plan to put any type of load in the bed, so at this point I do nto see the need for the notch. However, there is a chance I may go lower, or even air bag it at some point and if I do this then I will use the notch. The ride of the truck is awesome, and even seems better than stock. I have no issue with steering, you can let go of the wheel at 60 MPH and it drives straight as an arrow. I only cut one turn off of the coils, so I have seen no problems with this so far. I have another kit for an F150 if you are interested.
Old Mar 6, 2010 | 10:20 AM
b_duncan's Avatar
b_duncan
I wanted to be able to hide my license plate when at car shows, I looked around online and found some plastic ones that ranged from $40-$150, so I made my own holder. Here some pictures of the hidden license plate holder I made. Started out as two heavy duty door slides from Home Depot, which cost about $6 each. The ones I bought were 18 inches long which worked out because it gave me extra material to work with.
After doing some measure on where I wanted the mount to be located, and how far I wanted it to drop down I began cutting. The first picture you can see the two slides, one is cut and the other is not.
The slides actually came with a good mounting bracket, but it needed to be welded so it would not come part(pic 2)
Old Mar 6, 2010 | 10:27 AM
b_duncan's Avatar
b_duncan
After cutting what I didn't need off of the slide, I turned around and weld the leftovers together to make the mounting braces that hold the plate. I used an old license plate to get everything lined up and to make sure it was square.
Leaving the plate attached to the mount, I cut away part of the license plate so that the mount could be welded to the two slides and everything would stay square.
Old Mar 6, 2010 | 10:33 AM
b_duncan's Avatar
b_duncan
I did not want to get pulled over for something as stupid as not having a license plate light(which does happen in California), so I had an old fiberglass spare tire cover off a ford van that I cut up to utilize the light from it.
After getting everything put together it then got welded into place under the truck.
Old Mar 6, 2010 | 10:35 AM
  #28
b_duncan's Avatar
b_duncan
Pictures of the holder fully retracted and extended.
Old Mar 6, 2010 | 10:37 AM
  #29
b_duncan's Avatar
b_duncan
Now you see it....Now you dont...
  #30
b_duncan's Avatar
b_duncan
Just a simple project I thought I would share..
