Pyrometer install
Old Dec 15, 2009 | 04:10 PM
andrewc53's Avatar
andrewc53
Pyrometer install
Where is the easiest place to install a pyrometer on our trucks? Is it necessary to remove the exhaust manifold to do it? I think I want a boost gage as well and think I can do that. What would be a last good gauge? Thanks A Curtis
Old Dec 15, 2009 | 04:14 PM
aklim's Avatar
aklim
Drill a hole in the exhaust manifold.
http://www.itpdiesel.com/other/7.3L%...structions.pdf
Old Dec 15, 2009 | 04:22 PM
7.3 Rocket's Avatar
7.3 Rocket
I'd recommend you install it in your up-pipe.
Old Dec 15, 2009 | 04:26 PM
Pocket's Avatar
Pocket
Exhaust manifold or up-pipe... take your pick.
I have had probes installed in both locations on my truck. Neither were particularly harder than the other. Both are correct locations, as they are pre-turbo installations.
As for brands of gauges, you'll get lots of opinions. I had Autometer in the past, and they were ok. Running DiPricol Optix now, and those are very nice.
Old Dec 15, 2009 | 04:40 PM
aklim's Avatar
aklim
Why the up-pipe? Isn't it closer to the piston itself in the manifold? Isn't that what we are looking for? The closes temp to the piston so we can avoid the meltdown?
Old Dec 15, 2009 | 05:20 PM
Pocket's Avatar
Pocket
With the location of the probe in the up-pipe, it's only a few inches away from the typical install location on the manifold. Temps are pretty much identical.
When I switched from an up-pipe probe to a probe mounted at the manifold, EGT readings remained identical on my truck.
Personally, I like mounting the probe in the manifold. It seems more "secure" that way. However, the probe in the up-pipe lasted several years without ever leaking or causing a problem. The only reason I switched from the up-pipe to the manifold was because I installed new bellowed up-pipes, and I didn't have the heart to drill a hole into those brand new beautiful pipes
Old Dec 15, 2009 | 05:23 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Its all them same on the temp side, but I also prefer the up-pipe since it is easier to drill and tap IMHO.
Old Dec 15, 2009 | 05:48 PM
big poppa's Avatar
big poppa
Another manifold install here too.
Old Dec 16, 2009 | 12:55 PM
andrewc53's Avatar
andrewc53
thanks for the tips and links. I think this is A job I can do when I save up some coin. A Curtis
Bowie
Sep 15, 2009 05:18 PM
dyoung14
13
Dec 23, 2008 09:06 AM
PAVEMENTMAN
24
Sep 30, 2008 04:49 PM
linkford
Apr 10, 2007 02:30 PM
edub32
Apr 5, 2005 08:20 PM
