Transmission problems (help!)
Old Dec 9, 2009 | 04:05 PM
pinheads52's Avatar
pinheads52
Exclamation Transmission problems (help!)
Hello,
I own a 2001 Ford Excursion with a 7.3L diesel with around 220,000 miles on it
and here recently its been having transmission problems,
such as shifting hard or late and my O/D off light flashes sometimes
I pulled the codes and these codes came up
P0732
P0733
P0781
I'm hoping this doesn't mean my tranny is going out, if anyone could help me out i would appreciate it.
Thanks,
Josh
Old Dec 9, 2009 | 04:37 PM
housedad's Avatar
housedad
List of codes
Ford DTC Codes
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0781 1 - 2 Shift Error
Bion
Old Dec 9, 2009 | 04:53 PM
housedad's Avatar
housedad
Possibles:
4X4 switch shorting or:
From the Ford Manual:
P0781, P0731 a
component:
SSA, SSB or Internal Transmission Components
Description:
1-2 shift error.
Condition:
Engine rpm drop not detected when 1-2 shift was commanded by PCM.
Symptoms:
Incorrect gear selection depending on failure mode and transmission range selector lever position. Refer to the Solenoid Operation Chart. Shift errors may also be due to other internal transmission concerns such as stuck valves or damaged friction material. May flash TCIL.
Basically, it is telling you to take it to the dealer for diagnostics.. Your internal solenoids in the trans could be going, or a electrical fauult in the shift lever.
We just had a thread on that, Shift levers are rubbing through a wire bundle and shorting. Check yours.
Old Dec 9, 2009 | 05:03 PM
housedad's Avatar
housedad
Here's the links:
https://www.ford-trucks.com/forums/9...ve-switch.html
https://www.ford-trucks.com/forums/7...-question.html
Old Dec 14, 2009 | 06:44 PM
sluggo39's Avatar
sluggo39
im trying to find the location of the output shaft speed sensor on my 2000 excursion
Old Dec 15, 2009 | 07:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's on top of the transmission at the rear of the trans.
Old Dec 15, 2009 | 10:08 AM
njstevens's Avatar
njstevens
I have had a hard shift from 1st to 2nd in my X pretty much when i bought it. It was in shop many times and nobody could figure out why. It just seems to be built that way. If I idle slow and easy it can be slight but if i get on her it slams 2nd almost like my mustang did back in 89.
Old Dec 15, 2009 | 12:00 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by pinheads52
2001 Ford Excursion with a 7.3L diesel...transmission problems...shifting hard or late and my O/D off light flashes sometimes
Sounds like the mechanical diode problem found in the 2001 tranny's.
Stewart
Old Dec 15, 2009 | 12:01 PM
Stewart_H's Avatar
Stewart_H
Sounds like you have an aftermarket valve body on yours.
Stewart
jcmagone
Jan 3, 2024 08:16 AM
59203shop
Oct 8, 2013 03:21 PM
iateatoad
13
Dec 8, 2012 10:35 PM
mhatlen
Mar 14, 2012 09:05 AM
okiebug71
Apr 29, 2010 02:05 PM
