OBD2 code of P1780
Old Mar 11, 2012 | 05:35 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
OBD2 code of P1780
Does anyone know what this code means ? P1780 transmission control circuit out of self test range. Curious if its a problem or tire size calibration. Mark.........
Old Mar 11, 2012 | 07:29 PM
senix's Avatar
senix
what year and what motor are we taking about?
Old Mar 11, 2012 | 11:45 PM
mhatlen's Avatar
mhatlen
Sorry about the lack of information, its a 2006 F250 4 wheel drive with a 6.0 diesel.
Old Mar 13, 2012 | 10:53 PM
Speicher's Avatar
Speicher
A P1780 code is generated when the PCM/TCM does not see a change in state in the TCS/Overdrive Cancel/Tow Haul switch during the KOER test, [Key On Engine Running]. During the KOER the switch needs to be cycled during the test.If the test was properly performed and the P1780 still exists the module did not see a change in state in the circuit, indicating a circuit, switch or module failure. Since the switch is operator actuated this is the only way the module can check this part of the system for proper operation, it cannot self test this part of the system on its own, hence the need for the switch to be operated during the test.
Old Mar 13, 2012 | 11:09 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Mar 14, 2012 | 09:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If your tow/haul button turns the tow/haul light on and off then the problem is you didn't press the button while running the test.
rustyandleaking
Dec 30, 2016 01:16 PM
Nathan511
Feb 29, 2016 07:56 AM
cpomike
Dec 23, 2004 09:12 AM
NH-F250
Jan 29, 2004 06:57 PM
