911 Help!!!
Old Dec 8, 2009 | 10:03 AM
PwerStroke99's Avatar
PwerStroke99
911 Help!!!
well, came out to my truck today after starting it up and noticed a puddle of oil on the ground underneath, in the area where the downpipe connects to the rest of the exhaust. The last time i saw this was when i changed the injectors out, went away of course at that time. But now the oil is back, leaving a pretty good puddle. And also, the truck is smoking like a siv! My first guess is Injector Orings. I put new Orings on them when i installed them. I guess something could have happened on install. But anyway, need some input
Thanks
Ken
Old Dec 8, 2009 | 10:07 AM
damons's Avatar
damons
I too have the smoking issue, no real oil to speak of, I just had my truck this morning at Ford for the speed recall and they told me it would need a diag, but first guesses are the EGR or control module for the injectors.
Old Dec 8, 2009 | 10:37 AM
PwerStroke99
there is no egr on the 7.3s. Mine is major, so it is either orings or turbo seals
Old Dec 8, 2009 | 10:40 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Did you use OEM O-rings or aftermarket? Was the oil coming out your exhaust or from somewhere else?
Old Dec 8, 2009 | 10:43 AM
Layson's Avatar
Layson
That sucks Ken,
I am sure you installed those injectors ok.... you torqued them down properly? Correct?
Old Dec 8, 2009 | 10:50 AM
PwerStroke99
Clay, the oil is coming out of the exhaust at the Exhaust/DP connection. I used OEM Orings.
Layson, Yep i made sure i torqued each injector down.
The truck fires right up also. and it is leaving a good amount of oil under the truck when idling.
Old Dec 8, 2009 | 10:51 AM
PwerStroke99
Clay, do u stock Orings?? Im hoping it isnt my turbo.
Old Dec 8, 2009 | 10:52 AM
Layson's Avatar
Layson
I am wondering if it is your turbo... does it idle fine?
Old Dec 8, 2009 | 10:54 AM
PwerStroke99
Seems to idle fine, i did get some romps this morning after it had been warm. I shut the truck down after i got out of it to go into the gym and then started it back up and it romped a couple times on me, the first time it has done that
Old Dec 8, 2009 | 11:04 AM
Riffraff Diesel
PREMIUM SPONSOR
Yep, OEM o-rings are in stock. I am wondering if it is coming from your turbo as well. Did you buy it new? Do you have the extra o-rings that come with it?
Old Dec 8, 2009 | 11:05 AM
PwerStroke99
I guess only one way to find out. Remove the DP and inspect it. Im guessing if it is soaked, then it is the turbo huh? It is a good amount of oil that is on the ground. Leaving a puddle about the size of pop can laying on its side. Maybe not quite that big. And u can see it dripping pretty good
Old Dec 8, 2009 | 11:20 AM
Layson's Avatar
Layson
If you can I would look at it. Maybe just start with the intake side of the turbo... then go from there.
Old Dec 8, 2009 | 11:23 AM
PwerStroke99
would intake side show signs of leaking?
Old Dec 8, 2009 | 11:32 AM
Layson's Avatar
Layson
Most likely not, I would just check to see if there is any play.... just for the hell of it before I ventured to the exhaust side. I would try to eliminate everything I could before anything else come off the motor.
Old Dec 8, 2009 | 11:35 AM
PwerStroke99
yea. THis really sux. Dont wanna drive it too much, but its my DD and dont really have anywhere to go to check this stuff.
