911 Help!!!
Old Dec 8, 2009 | 01:57 PM
  #31
PwerStroke99's Avatar
PwerStroke99
ugh, this sux!!! Might just ordr a new one and then try and send this one off to be warrantied and see where it goes. cant have the truck down for too long for them to decide if they will warranty it or not.
Old Dec 8, 2009 | 01:59 PM
  #32
Layson's Avatar
Layson
I have a stocker you could throw on there for now... Just be easy on it...
Old Dec 8, 2009 | 02:01 PM
  #33
tdpower's Avatar
tdpower
I would think you could idle it with the intercooler tubes off and probably would see it spitting oil. Starting to sound like boom part 4. Joe (Izzy) I think has a similar problem boom part 3.
Old Dec 8, 2009 | 03:32 PM
  #34
PwerStroke99
A buddy of mine here in town has a stocker im probably going to throw on her. Try and send the 38R back for possible warranty work and see if it can done or will be done. then in the meantime im going to look at different turbo options. Inputs are welcome.
Old Dec 8, 2009 | 03:45 PM
  #35
Layson's Avatar
Layson
Greg has a very nice setup... by the time you sell your turbo and up pipes you can call it even....
Old Dec 8, 2009 | 03:51 PM
  #36
superduty4x4's Avatar
superduty4x4
I agree with Layson, go for the 42 series charger or something similar. Why the heck not if your 38R took a dump?
Old Dec 8, 2009 | 04:08 PM
  #37
PwerStroke99
Right, but i need to try and get the 38R fixed before i can even try and get any money out of it. Need to call Garrett up and see what they say. cross my fingers.
Yea Gregs setup is nice. Been talkin to JDUb about the Modified QSSB, but it is a chunk of change. but it does come with everything i will ever need to install it. No serious downtime for modfication/fabrication, etc. bolt it in and go
Old Dec 8, 2009 | 04:11 PM
  #38
PwerStroke99
Need an stock intake tube from filter tube to the turbo
Old Dec 8, 2009 | 04:53 PM
  #39
superduty4x4
What happened to yours, did you sell it with your AFE? Pull and save might have one.
Old Dec 8, 2009 | 04:55 PM
  #40
Layson's Avatar
Layson
I have one if you need it....
Old Dec 8, 2009 | 05:31 PM
  #41
PwerStroke99
Might take u up on it Steven. U will get it back once i figure out my turbo siutation afterwards. Thanks
Old Dec 8, 2009 | 05:57 PM
  #42
Layson's Avatar
Layson
Sounds good. I will bring it with me to work tomorrow just in case
Old Dec 8, 2009 | 05:58 PM
  #43
PwerStroke99
Sounds good. I could have the stock turbo tomorrow also.
Old Dec 8, 2009 | 06:11 PM
  #44
tdpower's Avatar
tdpower
If you are leaking oil out the connections from the manifold to the uppipes you might have a leak and loosing boost. Just a thought.
Old Dec 8, 2009 | 06:46 PM
  #45
PwerStroke99
Ok, well, i went to start my truck to come home tonight and it wouldnt start, all it would do is crank and crank and crank and smoke like a son of a gun! So I am guessing turbo is good, i have a bad injector oring somewhere!!!
Anyway i can tell which injector it is???
