yeah and I bet it is nice and warm outside too... I can't believe how cold it has been getting, crazy!
I guess i will try and get with dale Isley and use his shop and see whta i can find. he is on the other side of town. Yea it is cold, low single digits here this morning
We have a pink Barbie jeep or a 50cc four wheeler you can borrow for a few days!
My gut is telling me your turbo somehow failed... When do you think you'll have time to look it over?
Well, i definitely have some good smoke, when i give it some throttle, it smokes like a freight train. and cruising it is smoking but not as bad. but it seems to be starting fine.
I inspected the truck some more here at the house, and im not getting oil where the exhaust manifold and uppipes mate at. The smoke is just a slight haze when cruising but when i give it some throttle, the cloud of blue smoke is heavy. trucks starts fine, and idles fine, doesnt seem to have a miss. Im leaning towards turbo oring failure
yea thats what im thinking too Chase. Ugh this sux!!! im going to try a couple more cold starts and see if it fires right up, without th auto start. If it fires right up, my suspicions will be accurate, Turbo
If it was an injector o ring leaking wouldn't it be a phantom oil leak and show up in the fuel filter?
that is true, since the orings separate the oil to the fuel then down to the cylinders...
Originally Posted by PwerStroke99
Good point Grant.. Anyone?
that is a good point since you would probably see an oil leak where the manifold and the up pipes meet. I am leaning towards the turbo too... sounds like maybe the seal for the BB cartridge ..
