tires/rims
Old Dec 5, 2009 | 08:47 AM
XBuford's Avatar
XBuford
tires/rims
I need tires. With that said, I think going to an 18 inch rim would be a nice upgrade. My X is a stock 4 x 4. What size rim/tirewould fit? Spacers needed? I'm looking for something simple like this
Old Dec 5, 2009 | 01:13 PM
02X72's Avatar
02X72
No one can answer your question without more information on the year of your Excursion, and more about the rims. You can do a search too and find tons of info
Old Dec 5, 2009 | 02:17 PM
XBuford's Avatar
XBuford
Yea, I figured.
My excursion is a 2002 PSD 4 x 4, all stock
Old Dec 5, 2009 | 02:30 PM
housedad's Avatar
housedad
you're going to have to stay within the size limits of a 285/75/16. The general concensus is that is the largest size that can go on a unlifted Ex.
33 inch diameter and I think a 11.2 inch section width
Old Dec 5, 2009 | 02:40 PM
XBuford's Avatar
XBuford
How much lift would I need? I think 18 and 20s are around 34 tall and the stock ones are 31
Old Dec 5, 2009 | 04:02 PM
housedad's Avatar
housedad
You are confusing wheel size with tire size. The diameter of the rim may be 16, 17, or 18 inches, but the tire size will determine the final diameter. You can buy tires in any of those rim sizes to reach a certain diameter.
However, if you choose a tire that is also too wide, then it rubs the inner fender or springs.
So, first choose your diameter tire you wish to go to. This will determine how much lift you need. Then choose the rim size. Then try to find a tire that will fit those dimensions without being too wide for the lift that you have chosen.
Bion
Old Dec 5, 2009 | 04:05 PM
XBuford's Avatar
XBuford
So, first choose your diamer tire you wish to go to. This will determine how much lift you need. Then choose the rim size. Then try to find a tire that will fit those dimensions without being too wide for the lift that you have chosen.
Bion
I'm not really new to tires or diameter or anything, I just hate typing so I never get information out that way I want to.
I want to run 33-34 inch tire, 18 or 20 inch rim... whatever is available. Nothing wider than 285mm. I love the way it looks after seeing others do this.
Old Dec 5, 2009 | 04:18 PM
housedad's Avatar
housedad
Ok, Sorry for the over info. I don't know how much someone on here know.
anyway, 285/75/16 can be run on stock rims. they are right at 33' dia.
If you want a 18 inch rim, a look at tirerack shows
285/65-18 32.8 diam. would need no lift
305/65-18 33.7 dia. Would need at least V codes to lift 1.5 to 2 inchces.
285/ 65 20 34.7 dia. will need 3 to 3.5 inch lift. no rub.
These are just my opinions, and just a example. YMMV
Old Dec 5, 2009 | 04:42 PM
TYZ78F150's Avatar
TYZ78F150
So a 4x4 X can fit the 285/75/16 with no rubbing? Mine is an o4' with the 5.4 and i'm in need of tires soon and would love to run those vs the 265's.
Old Dec 5, 2009 | 05:07 PM
housedad's Avatar
housedad
according to all the reports of people who have done it, yes, 285/75-16 will fit the stock setup.
do a search and confirm it.
66gpw
Jun 2, 2012 07:47 AM
RIKIL
Mar 11, 2009 12:10 AM
Dieselman929
Aug 4, 2005 09:53 PM
ronjoli
May 9, 2002 12:51 PM
