IMPORTANT: CPS PHANTOM CODE INFO
Old Feb 23, 2010 | 06:38 PM
  #61
4inchlovin's Avatar
4inchlovin
All trucks are involved in the ORIGINAL CPS recall... This new info that i posted IS NOT a recall. Just some useful info if you are having issues with a gray CPS.
Old Feb 23, 2010 | 08:21 PM
  #62
F350-6's Avatar
F350-6
Originally Posted by trey99
i take it not all trucks are involved in this recall. i called today and they said my vin did not have that recall on the oasis report?
If you've got a 99 - 03 7.3 diesel that was sold in the US or Canada, then yes it is affected by the recall. That is unless the updated CPS has already been installed. Of course, as this thread indicates, you're often better off not doing the recall anyway, but if Ford says your truck does not need the recall, then odds are, it already has the new gray CPS.
Old Apr 4, 2010 | 02:57 AM
  #63
Skip1970's Avatar
Skip1970
what is a good part number for the cps for a 2000 7.3? i need to get one on order to have a spare, anyone got online order place for one of these?
I would like to put the new one in and use the old one for a spare.. no recall on the cps was done to mine so far that i know of. mine was a canadian excursion and imported to usa.
Old May 1, 2010 | 02:12 AM
  #64
van_350sd's Avatar
van_350sd
I will help you out a bit,
Mike at Tousley Ford will sell you one for 18.73, the new 1876736C91 and it's the Dark Blue Color, they look black in low light.
Ford Part # F4TZ-12K073-C
International Part # 1876736C91
The bad gray Ford CMP Units are the 1876735C91 ( 35C91 ) is the one you don't want to buy.
Both the New Ford Dark Blue CMP and the International CMP both have the same build numbers,
1876736C91 etched in the top of them. They are the same units, no matter where you buy them.
If you buy from Tousley ask Mike in a note to ship it to you via the 2-3 day Priority Mail and you will get it fast.
Check to see if yours are the Gray units, 1876735C91, if so they seem to use more fuel in the timing and they sometimes skip Cylinders #1 & #4.
They are giving the Gray units away now because of the failure rate.
The newer 1876736C91 Dark Blue units seem to work much better, fire on all 8, so check em out.
Now, What does a CMP Do?
The CMP is so important, it's like the pacemaker of the engine.
As the cam spins there are 12 points of the cam wheel that communicate with the CMP, the other parts of the cam are milled deeper so the cam will not count that part as it spins via
engine speed.
Then Fuel timing control,
Engine mode selection
Injection control pressure
and Exhaust back pressure.
This small device sends a 12 volt signal 12 times per revolution,
and all the other voids in the cam wheel send 0 volts.
So it's basically flashing a signal on, off, on off to the Computer
and this affects the fuel delivery, timing and what I mentioned above.
So the faulty CMP's are throwing false readings to the Trucks computer
causing misfires and dumping fuel in the engine when it does not need it.
There are a few design flaws in the current CMP's and a new improved unit
will be developed soon.
Old May 1, 2010 | 03:09 AM
  #65
Skip1970's Avatar
Skip1970
i ordered on already it was grey! dang it, so how do i get in contact with this mike guy to get the dark blue one for my 00 excursion 7.3
Old May 1, 2010 | 08:58 AM
  #66
van_350sd's Avatar
van_350sd
I posted the Ford Part in the above reply, when you go to the website to order the unit, at the end, credit card info part you can add a note, Mike is the only one that does the parts there.
Best,
Old May 2, 2010 | 12:41 AM
  #67
Skip1970's Avatar
Skip1970
Best,
but what website? i have no idea where to go..
Old May 2, 2010 | 03:33 PM
  #68
van_350sd's Avatar
van_350sd
Tousley Ford Parts Depot
Click on the pop up and select Ford after you put your part number in.
tousleyfordparts D O T c o m
Best,
Russ
For some reason the link I provided before got removed.
Old May 7, 2010 | 10:30 PM
  #69
Waynenap's Avatar
Waynenap
I just had mine done at the local ford dealer and the part number on the work receipt is: F7TZ-12K073-B. There is no International designation on the receipt. Is this the culprit everyone is ranting about?
Old May 8, 2010 | 01:29 AM
  #70
van_350sd's Avatar
van_350sd
Wayne,
The International Numbers are etched into the Top of the CMP Units, near the plug. You can only see them when they are in your hand, not installed.
The part number F4TZ-12K073-C (1876736C91) (New Dark Blue Color) supersedes old part number F7TZ-12K073-B (1876735C91 ) Old Gray Recall Color) , in other words, the old Gray unit is replaced by the new Dark Blue Unit.
The 18767 part of the numbers is for the 7.3L Engine.
The 35C91 is the Old Gray "Defective Part or Bad Luck Run Units)
The 36C91 is the New Dark Blue (Improved Sensor)
For Some Reason Both Ford & International both Share the same Units and they went back to the Tinned Contact Pins (It's like a silver solder coating on the copper) on the new Dark Blue units.
The Gray Units have the Gold Plated Pins and they have had so many problems with them. Many people have used a Wire brush Pen to clean the Gold Pins (3) contacts. They just scratched the pins the best they could because they are way back in the device. Sandpaper, anything to clean the gold off.
Some People have even Bead-Blasted the gold off the pins to the bare copper.
I would just buy a F4TZ-12K073-C if they installed the junk Gray in my Rig.
Watch your EGT's with the Gray units.
Have Fun with your Ride.
Old May 8, 2010 | 01:37 AM
  #71
van_350sd's Avatar
van_350sd
I typed this a while back and I saved it, so I copied and pasted it here to help some people who do not know what the CMP or CPS ia all about.
One of the biggest problems with most of the 7.3L Rigs is the Gray CMP installed by the Dealers after the Re-Call.
If you have the Gray CPS I would replace it with the new Dark Blue Unit, here are the numbers and where to get them.
Mike at Tousley Ford Parts dot com will sell you one for 18.73, the new 1876736C91 and it's the Dark Blue Color, they look black in low light.
As the cam spins there are 12 points of the cam wheel that communicate with the CMP that send a 12-Volt Signal to the PCM and the other parts of the cam are milled deeper so the cam sensor will send a 0-Volts signal to the PCM so it gets Twelve / 12-Volt Signals per revolution. I marked the photo below to show the cam wheel and to explain the general scope of the Cam Position Sensor.
1) Checks - engine speed.
2) Then Fuel timing control,
3) Engine mode selection
4) Injection control pressure
5) and finally Exhaust back pressure.
(That's a lot of responsibility for one electronic device)
So it's basically flashing a signal on, off, on, off, on, off, o,n off, to the Computer.
There is an "Air Gap" that the sensor is designed
to have when you bolt it on the truck using a single 10MM Bolt @ 18 Ft. Lbs. Torque.
Be sure to coat the O-Ring with Dielectric Grease before he installs it.
Also causing high EGT's, Poor Timing, and very Poor Fuel Mileage Per Gallon.
The part number F4TZ-12K073-C (1876736C91 supersedes old part number F7TZ-12K073-B (1876735C91 ) , in other words, the old Gray unit is replaced by the new Dark Blue Unit.
Old May 10, 2010 | 02:44 PM
  #72
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
hum,,,,
F4TZ12K073C is for 94-96
F7TZ12K073B is for 97-03
F4TZ12K073C does not supersede or replace the F7TZ12K073B they are both good and valid part numbers.
just wanted to clarify for the record. also if it works for the 97-03 trucks and everyone is cool with it. I'll sell them to ya!
Old May 10, 2010 | 07:39 PM
  #73
Waynenap's Avatar
Waynenap
So, anyway, bottom line, can anyone tell me for certain what I have just done, or accomplished?
I replaced my sensor under recall just last week with a F7TZ-12K073-B.
I just ordered a F4TZ-12K073-C from Tousley ford sunday because I thought the F4 was a piece of crap.
Old May 10, 2010 | 07:50 PM
  #74
F350-6's Avatar
F350-6
I bought a 1821720C99 from Jody back before all the original black ones disappeared. That's International's part number for the 94 - 96 CPS. When I noticed the difference and asked him if I shouldn't have the C93 for my 02, he stated he tested both of them in his (Diane's) 7.3 and could not find a difference between the two with all his fancy equipment.
I put this in October of 08 and run between 40k - 50k a year. Smoother idle than the Gray CPS I had in there and no issues with mine yet. I'd say spending the $20 or so on the 94 - 96 CPS is worth it if it makes your truck run better. Here's the link to my thread from the original swap. https://www.ford-trucks.com/forums/7...-cps-test.html
Old May 10, 2010 | 08:54 PM
  #75
Waynenap's Avatar
Waynenap
Well I guess I'll try it out. Hope I'll be able to tell the difference in how it runs.
