I have it in writing from Corporate Ford. That they are aware of Phantom Code issues with the New Grey CPS. Phantom Code issues that "May also exhibit drivability symptoms (running rough, miss, buck/jerk, hesitation)"
I got my friend down at the dealership to print it out for me. It is NOT a TSB but just a "Special Service Message" Here it is in black and white for all to see.
Please let me know if you want the info in a form besides pdf. and I will send it to you.
I don't have a problem with the gray one, I hope they find a fix before I start having problems.
Thanks Nolan.
I don't think you'll start having problems Rick. The trucks that don't like the gray CPS don't like them right away. Your truck likes them so I'd suggest you pick up a couple of extra gray ones when they announce whatever "even newer" improvement.
I have a black and a grey CPS. Grey installed and black in the door just in case. Guess I'm lucky in that my seems to not mind either one... knock on wood...
Very good detective work Nolan. They really don't want you to know about Any problems. The grey one seems to work fine in my truck but where can I get a black one and what should it cost?
