Diagnostic Scanner Tool - Help
Old Oct 4, 2009 | 11:09 AM
Florida F250's Avatar
Florida F250
As a new PSD owner, I have recently had some issues with my truck of late and have realized just how impossible it is to trouble shoot what could be a minor problem without the aid of a scanner, unlike my old IDI F-250.
After having my truck towed to a repair shop, so far it appears that the solenoid in the #8 injector is bad or that its wire harness may need to be replaced. Also the CPS needs replacement, which I already did just before sending it to the shop, however the shop still needed to reset the error code for it.
With a scanner I could easily have figured this out for myself, performed my own labor, and minimized the down time for my truck.
- What diagnostic scanning tools are there available (with ability to diagnose, trouble shoot and reset codes) and that you recommend?
- Are there any priced within the means of a vehicle owner rather than the owner of a repair shop?
Thank you in advance for your sage advice!
Florida F-250
Old Oct 4, 2009 | 11:16 AM
Izzy351's Avatar
Izzy351
There are several options. I personally like my Scan Gauge, as it's there full-time for reading all kinds of parameters, any codes, and resetting them. For data logging and more detailed analysis, AE is the way to go. Even though I have a Scan Gauge, I could use the more detailed capabilities of AE.
There are also combination tuners/programmers that read & reset codes, so it's up to you, your wallet, and your goals. AE is close to $400, IIRC, the Scan Gauge is $269, and programmers/tuners vary.
Here's where I got my Scan Gauge:
Terminator Engineering
Old Oct 4, 2009 | 07:27 PM
Florida F250
Thanks so much! I appreciate the input and will be purchasing a scanner in the very near future!
Florida F250
Safe driving!
Old Oct 4, 2009 | 07:32 PM
Layson's Avatar
Layson
Send an email to Clay at Riffraff and pick up AE. sales@riffraffdiesel.com That is where I got mine from. You can monitor all the engine sensors and even change your speedo for different tire sizes.
The scan gauge is cool and handy, but not near as powerful as AE.
You can get AE for about the same price as a visit to Ford.. LOL
Old Oct 4, 2009 | 07:43 PM
farmdad's Avatar
farmdad
Do the AE. I've used it on quite a few vehicles and it is easily paid for by the savings from going to the repair shop. Did a neighbor's Excursion recently and found out that it even diagnoses the backup sensors. So I did mine and found out which sensors had failed.It is a very powerful tool.
Old Oct 4, 2009 | 07:44 PM
Layson's Avatar
Layson
I need to start charging now... once people find out you have it... all of a sudden you are their new friend.. hahahaha...
Old Oct 4, 2009 | 07:51 PM
Bigcat350's Avatar
Bigcat350
The AE is a nice tool. I am glad I have a Friend close to me with one or I would for sure buy one
Old Oct 4, 2009 | 08:44 PM
Izzy351's Avatar
Izzy351
You can do all that with the gauge. I'm glad I have the gauge, but the only thing I can't do is data log for graphing purposes. It actually does record 60 seconds of data for later review, but I like the graphing capabilities of AE.
Old Oct 4, 2009 | 09:32 PM
Layson's Avatar
Layson
I didn't realize it does tire size calibrations?
How many tests can it run on the motor? I thought it just did buzz test and Cylinder contribution...
Old Oct 4, 2009 | 10:15 PM
Izzy351's Avatar
Izzy351
The link to it is above. It lists the stuff it does. Or you can read the directions that come in printed form with it here:
http://www.aeroforcetech.com/files/I...AL_rev_2_4.pdf
Old Oct 4, 2009 | 11:00 PM
donnyglaze's Avatar
donnyglaze
Not to sound too ignorant on the subject, but can you run this along with the whole Banks 6 gun setup?
Old Oct 4, 2009 | 11:21 PM
Layson's Avatar
Layson
It is an independent system... doesn't matter what chip you run.
Old Oct 4, 2009 | 11:22 PM
Highboosted's Avatar
Highboosted
The scan tool and a programmer do not interfere with each other, as they do completely different things.
The scanner just reads PCM data from various sensors.
[edit]: I got beat, lol. Anyways, if your programmer changes how the PCM sees certain data like boost or ICP, the scanner will show the changed data and not the actual readings.
Franko72
Mar 12, 2013 12:44 PM
hydraze
1997 - 2003 F150
Jan 25, 2012 09:18 PM
palindromelol
Jan 18, 2012 06:57 AM
traxx808
May 2, 2011 09:13 AM
quisp-n-quake
Jan 21, 2006 06:03 PM
