Sponsored by: Auxito
DLC not working...help
Old Jan 24, 2012 | 05:33 PM
hydraze's Avatar
hydraze
Anyone in here electrical savvy? I have an issue with my data link connector on my 2000 f150 XLT, 4.6L
I ran an OBD2 scanner several times on this truck before I took in to the transmission shop. I had one code and it worked fine. While at the shop, negotiations broke down over their labor rate and I elected to pull my truck out. I paid tow and diagnostics to the shop.
Now at home, I tried to scan the truck again because the service rep told me they pulled a code for an EVAP leak, but now my scanner is not communicating with the DLC. Usually I don't need to turn on the scanner, just plug it, turn ignition to on position, and reads the code. Now I get nothing.
What could have happened in the shop that now my scanner has no communication with the DLC?
what I've done so far(from what little I know):
-the scanner is fine, new batteries and also I scanned another car, and it worked fine.
-I checked all the fuses under the hood. I don't know what I might have missed.
Anyone out there that can help, please do. I really need your help. ....Thanks
Old Jan 24, 2012 | 06:12 PM
projectSHO89's Avatar
projectSHO89
Cigar lighter fuse also powers pin 16 of the OBDII connector.
Old Jan 24, 2012 | 06:46 PM
jyount's Avatar
jyount
x2 Anything that is OBD2 (that is 1998 and up) the DLC is always powered by the cigarette lighter fuse, which is in the cab on that truck. I forget what # it is, but I seem to remember it was a 20 amp.
Old Jan 24, 2012 | 07:25 PM
cjtim's Avatar
cjtim
if it isnt a fuse or power issue, ive had to pull the batteries out of my tester a few times when it wouldnt read, you know how electronics are.
Old Jan 25, 2012 | 07:09 AM
hydraze's Avatar
hydraze
Thank you.
I will check that out today
Old Jan 25, 2012 | 09:42 AM
critterf1's Avatar
critterf1
I thought it was 30 AMP. Owner's manual will show it.
Old Jan 25, 2012 | 10:28 AM
cchandler4704's Avatar
cchandler4704
pins pushed
Check the connector where the scanner connects for loose wires, possibly a wire pushed out the back. Also check the ground connection form the wire it the connector to the ground. I had a bad ground from the connector to the frame and it took me like 6 days to figure it out. Good luck.
Old Jan 25, 2012 | 09:18 PM
hydraze's Avatar
hydraze
thank you folks! it was just a 20 amp fuse. It works fine now.
69highboy69
1983 - 2012 Ranger & B-Series
Feb 1, 2013 03:25 PM
swillett
1997 - 2003 F150
Oct 30, 2012 07:33 PM
jlarsen513
Modular V10 (6.8l)
Sep 11, 2011 05:04 PM
sun622
Escape & Escape Hybrid
Jul 8, 2011 06:58 AM
BeauHymel
Aug 31, 2009 09:40 AM
