Something Gone Wrong
Old Sep 24, 2009 | 05:38 PM
  #76
strokersace's Avatar
strokersace
Pat hopefully it works this time around. I hate it when I do a mod that EVERYONE else has already done and it doesn't work like it should the first time. You'll get it hammered out and be alright.
Old Sep 24, 2009 | 07:30 PM
  #77
spdmpo's Avatar
spdmpo
In my opinion for you to collapse a pretty stiff fuel line with the factory pump, there has to be some kind of restriction somewhere before the point where it collapsed. Shouldn't have anything to do with the length of the hose.
Old Sep 24, 2009 | 09:02 PM
  #78
mechelement's Avatar
mechelement
Originally Posted by just another truck
I Used a pry bar and a log, with a second log on the side, I worked the tank up on when end until I go close to center, once there I leaned on the tank ans hoved another log under the other side, thats how I got her off the ground. I raised the tank, and listend to teh pump, then lowered the tank and looked at the line, IT collasped, I again took the tank apart, inspected everything.. saw nothing, Called Meggawatt while taking a break, he suggested the hose might be wrong..So, off I went, back under the truck, adn I lifted and lowered, and what I believe I found was not that it was the wrong hose, but that maybe I still had it to long.So, I have both hoses maybe less then three inches, Raised the tank, it brought the tubing up with it a little. Put the key in the ignition and listened, the pump didnt sound the way I thought it should, but it is a new pump. I lowered the tank again, found no crimps. Raised the tank and cycled the key about 10 times. There still were no kinks. I secured the tank, secured teh cover, took her for a ride, and as of right now, she is running good. So, I am now going to try and get my home work down and get off to school.
I will let everyone know if something changes, adn thank you all for your support!!!!
That is so weird. So the line is collapsing because it's too long? I guess I don't understand what's going on, but would be equally as frustrated as you.
I've been ***** to the wall with studying all week for my two math exams (DE & Prob. & Stats.) tomorrow. Going back to school has been a PITA.
Good luck and hopefully you've fixed the fuel line issue.
Old Sep 24, 2009 | 09:20 PM
  #79
spdmpo's Avatar
spdmpo
What size line are you using btw?
Old Sep 25, 2009 | 09:35 AM
  #80
just another truck's Avatar
just another truck
3/8's line, and yeah, I am with you on the question of, why would to long be an issue. Second day driving and still no problems, pump sounds fantastic. I figure I will wait a week, and drop the tank and re set up my pick up to where it belongs.. I just dont learn, do I?
Old Sep 25, 2009 | 09:43 AM
  #81
jcrammell's Avatar
jcrammell
Dang Pat, You got your workout for the month on that mod. Hope that fixed your problem though. I am thinking about doing this mod so I am watching closely so I know how to fix it if it happens to me. Good luck
Old Sep 25, 2009 | 10:02 AM
  #82
just another truck
I am going to suggest that you just replace the whoe 10' with hose, so as not to play with this as long as I Had..
Old Sep 25, 2009 | 10:53 AM
  #83
PaysonPSD's Avatar
PaysonPSD
3/8's line, and yeah, I am with you on the question of, why would to long be an issue?
The extra length of the added fuel line may have caused it to kink when you raised the tank to it's final position. JMHO.
I'm certainly glad that it seems to be OK now.
Old Sep 25, 2009 | 03:15 PM
  #84
Ponyboychris's Avatar
Ponyboychris
That was my suggestion/thought/guess as well as I mentioned when I had the same issue with my old Bronco years ago. It drove me nuts as well. It wasn't because of an extra length, just how it all fit when I raised the tank into the frame. Anyway, Pat I hope this is it for you, buddy!
Old Sep 25, 2009 | 03:56 PM
  #85
Smokin''s Avatar
Smokin'
Smokin
Glad you got it worked out Pat. Wow, what a marathon. Are you still wearing your decorations?
Old Sep 25, 2009 | 05:37 PM
  #86
just another truck
So far so good, it does look like the hose was pinching right up next the frame. In another week or so I will drop the tank and re hang the pick up to the right length, but I think I got it, of course with the help and support of this group.
I have to tell you Lisa, if I didnt get yesterday, I was giving you a 25 hour warning, I was heading your direction for help. I figure 25 hours at a max speed of 35..that would have been a long trip.
Old Sep 25, 2009 | 06:43 PM
  #87
Smokin''s Avatar
Smokin'
Smokin
Well, it'd give you time to work on improving your butt groove...
I'm here for any weary FTE travelers who want to stop on by!
I bet you can give lessons on how to drop a tank now though eh? Practice makes perfect.
Old Sep 25, 2009 | 06:56 PM
  #88
just another truck
To much practice makes you grumpy!!!
If I make it to Jims, I will volunteer for the intake mod for him, I have the practice..I hope he wont have to drive to far afterwards..
Old Sep 25, 2009 | 06:59 PM
  #89
87 F-150 I6's Avatar
87 F-150 I6
Glad to see you nailed the problem! I also need/want to do the hutch and harpoon mod, just no time right now. I should have you down to help, YOU are the pro now
Old Sep 25, 2009 | 08:24 PM
  #90
hucka1a's Avatar
hucka1a
I'm glad to hear that you got it, Pat.
datdawg
17
Jan 11, 2011 07:33 AM
cdevor
Sep 15, 2010 08:11 PM
red rock 78
Jun 30, 2010 09:22 PM
cc335
Aug 7, 2009 11:15 PM
hink10
24
Feb 19, 2006 01:48 PM
