Sponsored by: Real Truck
Urgent.
Old Sep 18, 2009 | 09:26 PM
  #76
EXv10's Avatar
EXv10
Looks like it is just a matter of replacing that piece now and the shifting problem will reveal itself soon also.
Old Sep 19, 2009 | 09:38 AM
  #77
cparks's Avatar
cparks
Is that shaft we are seeing in the pictures going into the transmission as I think it is? I have had many of the older E4OD, C6, AOD, etc apart and in those that shaft stays in the trans.
Old Sep 20, 2009 | 03:17 PM
  #78
BigJ5656's Avatar
BigJ5656
yeah, that shaft you are seeing does go into the transmission.
I was thinking if that driveshaft explosion cracked this tailshaft housing or whatever it is, I hope it didnt crack anything inside the trans. So im going to drop the pan, pull the torque converter and change the oil while carefully looking for metal shavings ...
Old Sep 20, 2009 | 04:09 PM
  #79
EXv10's Avatar
EXv10
The tranny is probably OK but I hope you can get that shaft back in.
Old Sep 20, 2009 | 05:26 PM
  #80
BigJ5656's Avatar
BigJ5656
well I think what ill do is try to get the first set of splines in, and if I can, then ill just end up putting it in neutral and spin it, hopefully itll slide inplace nice.
nhill2090
21
Jun 30, 2021 07:06 PM
GM4WALLS
Dec 24, 2013 10:22 PM
supertramp1221
Apr 23, 2011 11:34 AM
Big Skier
25
Jan 17, 2011 03:10 AM
6.0superduty
Nov 24, 2007 01:46 PM
