New engine questions
Old Dec 24, 2013 | 11:06 AM
GM4WALLS's Avatar
GM4WALLS
Looking to get a long block at the beginning of the year. My questions are as follows...
#1- Front or rear dipstick? Does it even matter? Mine is in the front currently.
#2- Head casting numbers. The options appear to be D8OE or D5OE. Also, do I need smog holes? (No emissions in my area).
#3- My current motor is tired, leaky and has a knock. Should I focus on just having the bottom end rebuilt and adding the same go fast goodies I planned on for the long block?
Old Dec 24, 2013 | 11:09 AM
ranger429's Avatar
ranger429
Skip the long block and have yours rebuilt, you'll know exactly what your getting.
Front dipstick is a car motor.
If you don't do testing skip the smog heads.
Old Dec 24, 2013 | 11:13 AM
GM4WALLS's Avatar
GM4WALLS
Front dipstick is a car motor? Interesting, my truck is numbers matching I assumed it was the original motor.
Old Dec 24, 2013 | 11:18 AM
ranger429's Avatar
ranger429
There is no such thing as numbers matching on your truck. There is no VIN number associated with the motor. And yes as far as I know the front dipstick is a car motor, front sump oil pan. A 4wd had a rear sump pan and the dipstick was located on the driver side of the block. Is your truck 2wd? May explain the front dipstick.
Old Dec 24, 2013 | 11:26 AM
GM4WALLS's Avatar
GM4WALLS
Yes, it is a 2wd.
Old Dec 24, 2013 | 11:40 AM
hivoltj's Avatar
hivoltj
My 2wd 400 has front dipstick and front sump pan. I would not trust a parts house reman engine. What motor is it and I can give better advice on what to do.
Old Dec 24, 2013 | 11:48 AM
GM4WALLS's Avatar
GM4WALLS
78' 302 stock. Want to do better flowing cast iron heads, mild cam, aluminum intake, 4bbl, headers, electronic ignition, and electric fan set up.
Old Dec 24, 2013 | 12:28 PM
AK FORD GUY's Avatar
AK FORD GUY
302's are a fun little engine.
If you were closer.... I have a really nice set of GT40 Cast Iron Heads. I bought them from a speed shop in Oceanside, CA. The owner was going to put them in his personal rig untill they went with a larger engine.
Also have a Weiand Stealth manifold and a Mallory Unilite Distributor.
I don't see me building another 302 for some time...
Old Dec 24, 2013 | 12:50 PM
GM4WALLS's Avatar
GM4WALLS
I may have to take a trip that way.
Old Dec 24, 2013 | 12:57 PM
AK FORD GUY
Come on up my friend, but bring a coat...
Eagle River, Anchorage, AK
Scattered Clouds
-7 °F
Old Dec 24, 2013 | 01:03 PM
caish's Avatar
caish
79 and earlier the dipstick is in the front.
Front Sump pans was used in most everything pre 1980.
1980 was the dividing year for trucks and Ford went to a rear sump pan.
Old Dec 24, 2013 | 09:30 PM
CDN Sharky's Avatar
CDN Sharky
I was gonna say my 67 falcon has a 302 from a 69 bronco in it and dipstick is in front as well.
Old Dec 24, 2013 | 10:22 PM
parkerparkerm's Avatar
parkerparkerm
ill sell you a 460 lol
my FE has a front dipstick, while my 400 and 460 have side? dipsticks. the hole is in the back that is.
mr_malina
Sep 23, 2017 01:09 PM
LittleLucy
Aug 25, 2014 12:45 PM
F-250 restorer
Nov 9, 2009 11:39 PM
1955effie
Jan 29, 2006 03:19 PM
BrentusBrutus
1978 - 1996 Big Bronco
Jan 20, 2005 07:41 AM
