need help!
Old Aug 22, 2009 | 11:23 PM
  #31
David85's Avatar
David85
Originally Posted by JNKDad
Ok let stry this again where is it my van consumed almost 5qts in the past Month. Almost killed my engine
Ouch.
In your van, you will probably have to take the inside engine cover off to find it. Its located right behind and below the air filter housing. It is about the size and shape of a tuna can. If its painted grey then its probably original. Sometimes you can clean them out with a gasoline bath, but when they get old the internal diaphragm will get hard and brittle. You might even see small pieces of it inside the engine intake. Anything found like that means you need a new one.
Ford or international part only, unfortunately. Autoparts stores won't have it usually.
Old Aug 23, 2009 | 09:05 AM
  #32
BlueOvalBud's Avatar
BlueOvalBud
dyoung...did you get the truck yet? What kind of plans do you have for it?
Old Aug 23, 2009 | 01:19 PM
  #33
Dave Sponaugle's Avatar
Dave Sponaugle
This is a CDR.
The one in the picture is off a turbo engine.
On the NA engine, the lower neck is longer so it reached the valley pan and it is bolted to the rear of the intake throat.
Old Aug 23, 2009 | 04:04 PM
  #34
dyoung14's Avatar
dyoung14
i havent got it yet cause i havent come up with all the money yet. but im trying hard, plans for it well getting it road worthy is the first plan, then i will move on too gauges stacks ram-air turn up pump, then maybe put a turbo on some time if i get it
Old Aug 23, 2009 | 04:29 PM
  #35
joe f350's Avatar
joe f350
but hows ur turbo going
Old Aug 23, 2009 | 09:53 PM
  #36
dyoung14's Avatar
dyoung14
i may sell it to buy the truck, if i dint buy the truck im still going to sell it to buy the older non wastegated psd turbo i like the idea of it better
IB Tim
Jul 3, 2011 10:46 AM
Iallwork
Jan 9, 2011 10:36 PM
superduty2004
Nov 7, 2008 11:13 AM
BobsF350
Mar 12, 2008 02:48 PM
motobub
Exhaust Systems
Mar 5, 2003 08:27 AM
