need help!
Old Aug 20, 2009 | 03:24 PM
dyoung14's Avatar
dyoung14
need help!
ok im thinking of buying this truck its in good shape, has a problem tho he says it will crank and run normal for about 5-10-15 minutes then it will start going into run away, i was thinking maybe cdr or ip what do yall think?
Old Aug 20, 2009 | 03:45 PM
84 f250 6.9's Avatar
84 f250 6.9
how much he want for it? lets hear some specs
Old Aug 20, 2009 | 03:46 PM
joe f350's Avatar
joe f350
is there a cl add i thought u died lol i know what cause this in turbo diesel is to turboed or na if turbos might be a bad seal some where and might be burn oil
Old Aug 20, 2009 | 05:23 PM
JesterPgh's Avatar
JesterPgh
From what I've learned here, it's probably sucking oil through the cdr, or it's low on fuel and sucking air. Mine will runaway if I let it get too low on fuel.
Old Aug 20, 2009 | 05:32 PM
joe f350's Avatar
joe f350
that what i think young do u need another truck for ur die
Old Aug 20, 2009 | 08:46 PM
dyoung14's Avatar
dyoung14
im about 99%sure its the cdr cause i pulled the air cleaner and it very oily, and also has anyone ever seen one with factory soup bowl delete? this one is but the hole that is in the air clear is very small and restrictive
Old Aug 20, 2009 | 09:17 PM
joe f350's Avatar
joe f350
u could you tube it what u need another truck for
Old Aug 20, 2009 | 09:54 PM
David85's Avatar
David85
Could be the CDR, or it could be massive amounts of blow by. What sort of power does the truck have? how much oil vapor comming out of the filler tube when idling hot?
Old Aug 20, 2009 | 10:02 PM
dyoung14's Avatar
dyoung14
havent bought it yet or seen it run, he askind 800 for it im going to try to get it for 650 has a nice body real straight no rust at all, specs its an 86 f250 4x4 6.9 t-19 n/a
Old Aug 20, 2009 | 10:05 PM
David85's Avatar
David85
You guys are really starting to **** me off. You can't even get a rust free 86 box for under $1000 up herelolz
Sounds like it could be a great deal but take your time here because a busted 6.9 isn't cheap to rebuild.
Old Aug 20, 2009 | 11:55 PM
dyoung14's Avatar
dyoung14
i dont care if the engine is f'kd i have a 83 model 6.9 has a 20.7:1 compression ratio thats just begging to go in it with some head studs and lots of turbo boost since its 83 it has factory lower compression
Old Aug 21, 2009 | 01:10 AM
David85's Avatar
David85
lol I stand corrected.....
Old Aug 21, 2009 | 08:39 AM
JesterPgh's Avatar
JesterPgh
Straight and rust free you say? I'd say that's worth picking up for sure, especially if you've got something else to drop in "just in case" anyways.
Old Aug 21, 2009 | 08:48 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
Did I not mention I paid $
Old Aug 21, 2009 | 08:50 AM
WEST AUSSIE 94 250
[quote=David85;7851907]You guys are really starting to **** me off. You can't even get a rust free 86 box for under $1000 up herelolz
Did I mention I paid $37,000.00 aus for my 94 7.3 extracab!!!!!
