Im anxious to see what kind of numbers you lay down Roland. I am Running Hybrids rightnow myslef with all the acompaniyng mods except for big oil. Hopefully by the end of the year I will be able to do the stealth 11 to keep up. Thanks also for all the great info you've provided to us here.
I made a second run with EOT @ ~203* and ICPs dropped an average of 40psi across the board.
Duty cycle #'s are lower now and pressures up slightly.
ICPs at idle 670-700rpms (hot) are ~490-500psi 10.55% DC
Running alot smoother now with less smoke.
Bounce those off of Jody. I am not sure what he is calling for but seem to recall it should not really be above 2800 or so. Looks like you are all set but I would check. That is the only reason I do not have an Adrenaline in my truck. I can maintain the ICP he called for while live tuning.
The current tunes are tweaked for the Stealth HPOP. I am guessing he is calling for pressures that are based on this and the Casserly Stage 2 singles. I would think the pressures, he calls for, would vary due to different types of injectors and nozzle sizes. One pressure may not be a "one size fits all" type of thing.
Now see, that is interesting info as the Stealth ought to be able to easily supply that. That is why I was curious about what he is calling for in Roland's case.
EDIT: Now that you mention it, that number somehow sounds familiar to me.
By the duty cycle numbers, it looks like the pressures could be higher if called for. It may be that Jody isn't calling for that much pressure (3145psi) in my case.
That is why I am curious. That 3145 rings a bell for some reason I cannot recall. I know 2800 will usually get it done but I don't know.
I am going to contact Jody and ask him about this. You've spiked my curiousity as well. It looks like the pressures are doing the the job though. Not near the smoke and EGTs I was seeing before.
Well Roland, I think you are good too except if Jody is calling for 3145 you ought to be able to make that no sweat. That is what has me curious. I would like to hear what he has to say about this, not that Diane doesn't read these threads too. Gonna have to drag it out of them?
