Stealth HPOP....WOW!!!
Old Aug 19, 2009 | 08:12 PM
  #46
mueckster's Avatar
mueckster
[LIST]
Originally Posted by indyF-350psd
hey man once you bleed off all the air can you post up your icp dc% at start up and after its warmed up at idle please? looking to compare numbers.........
Originally Posted by spdmpo
Roland, any data as far as pressures and duty cycles on the new pump for us?
Here's some numbers for all you "number junkies".
Idle (warmed up) 80e
Rpms 670-700
ICP 621-628 psi
ICP % 13.28
Data logged in 140a tune (WOT):
Old Aug 19, 2009 | 08:40 PM
  #47
zx250's Avatar
zx250
Of the next Riffraff East
WOW! You gonna put one on for me at the next RRE?
Old Aug 19, 2009 | 09:12 PM
  #48
mueckster's Avatar
mueckster
Sure, Barry. I'd be glad to. That booger is a tight fit in the valley, but it was all worth it. I am so pleased with the outcome.
Jody emailed me back this morning. Sounds like he already has some files on the Stealth and knows what to do with my tuning to bring it to the next level. I need to contact him about the chip reburn and get'r done.
Old Aug 19, 2009 | 09:19 PM
  #49
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
only 103? pfffff......... we want some real numbers! lol! j/k
thanks for posting up the numbers i asked for.............
Old Aug 19, 2009 | 09:27 PM
  #50
mueckster's Avatar
mueckster
I let out of it at 108 mph. Running out of road. EGTs hit 1400. Not too bad for a short term.
I didn't get to do a cold start. Had to be at work at 6:30am the last three days. I will try to get those numbers in the next few days, if you still want them.
Old Aug 19, 2009 | 09:33 PM
  #51
Bigcat350's Avatar
Bigcat350
108 mph Dang Roland you was rolling. Glad to hear this and thats some good numbers. I would like for you to put one on for me to.
Old Aug 19, 2009 | 09:44 PM
  #52
mueckster's Avatar
mueckster
I floored the throttle when I hit ~60 mph in OD and it downshifted into Drive. I held into it until it shifted back into OD at ~85 and finally let out at 108 mph. There wasn't any lag when I nailed it. It just took off!
If I get enough requests, I'll have to become a Stealth dealer.
Looks like I may be looking into a 1.15 A/R turbine housing in the future, too.
Old Aug 19, 2009 | 10:23 PM
  #53
countrycar's Avatar
countrycar
Good Job Roland. Now change your Sig.
Old Aug 19, 2009 | 10:41 PM
  #54
mueckster's Avatar
mueckster
Thanks. It's a done deal.
Old Aug 19, 2009 | 10:57 PM
  #55
countrycar's Avatar
countrycar
DOH, ... guess I missed it. Sorry.
Old Aug 19, 2009 | 11:09 PM
  #56
mueckster's Avatar
mueckster
You didn't. I changed it right after you said something about it.
Old Aug 19, 2009 | 11:11 PM
  #57
big poppa's Avatar
big poppa
Hey Roland, really shows one mod turns into another, fun isn't it..
Old Aug 19, 2009 | 11:29 PM
  #58
countrycar's Avatar
countrycar
I've been struggling on whether to buy the Adrenaline or save for this Stealth pump. I think you helped make my decision. Gonna save for the stealth. Thanks Again.
Old Aug 20, 2009 | 07:19 AM
  #59
Neal 97 250's Avatar
Neal 97 250
Those are definately some good numbers. I was talking with Jody when we live tuned and he told me he asks for 3145 psi. I was wondering why your numbers are not closer to the 3000 mark. Any idea?
You mentioned more tunes. What does he have for the stealth that is different than what he did when you were tuned?
Inquiring minds want to know. ME!
Thanks for posting up those numbers.
Old Aug 20, 2009 | 08:25 AM
  #60
mueckster's Avatar
mueckster
When Jody live tuned my truck, he couldn't get stable ICPs at an idle and when decelarating. I think this was due to a faulty IPR. Also. the ICP was low (read "crappy") is all my tunes above 60e. He lowered my ICPs to try to compensate for this. I believe the PCM is not calling for the higher pressures he normally asks for. He is going to reburn a chip to raise the ICPs to the desired levels and tune for the addition of the Stealth Pump. I think I am capable of higher pressures. Just, the PCM is not asking for it with my current tuning. I will have to data log the ICPs again after this is done. I should be seeing a nice increase. My EOT was a bit high also when we live tuned. I am changing back to the stock 'stat. Cooler oil may give me a few more psi.
