2007 F150 error codes
Old Aug 3, 2009 | 12:33 PM
jjc103's Avatar
jjc103
I have a 2007 f150 that just threw 4 codes of P0132 P0133 P2196 P2195. The truck runs and idles rough then appears to smooth out then rough again. Any help would be greatly appreciated.
Thanks, Jack
Old Aug 3, 2009 | 03:41 PM
jjc103's Avatar
jjc103
<TABLE border=0 cellSpacing=0 cellPadding=0><TBODY><TR vAlign=bottom><TD width="100%">2007 F150 error codes <!-- END TEMPLATE: navbar_link --></TD></TR><TR><TD style="FONT-SIZE: 10pt; PADDING-TOP: 1px" class=navbar colSpan=3> <!-- BEGIN TEMPLATE: navbar_link -->Reply to Thread <!-- END TEMPLATE: navbar_link --></TD></TR></TBODY></TABLE>
Also stalls at idle.
Old Aug 3, 2009 | 06:34 PM
wildcard30's Avatar
wildcard30
For the P0132 code check this link - http://www.obd-codes.com/p0132
For the P0133 code check this link - http://www.obd-codes.com/p0133
Here's the meaning of the other 2 codes:
P2195 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 1)
P2196 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1)
Have you checked the wiring or replaced the O2 sensor to see if that helps? Also, since it's a 2007, is it still under the new vehicle warranty? It may also still be under the emissions warranty.
Old Aug 3, 2009 | 06:52 PM
Oldguy4's Avatar
Oldguy4
wildcard30 beat me to it. I was going to send you to the very same links.
Deckmonkey
2004 - 2008 F150
Feb 21, 2025 04:36 PM
Tile man
2004 - 2008 F150
Apr 18, 2017 08:51 PM
Jonathan Day
2004 - 2008 F150
Oct 3, 2016 04:06 PM
cottrellp
2004 - 2008 F150
Jun 13, 2010 06:21 PM
badazzharley
2004 - 2008 F150
May 1, 2009 08:32 PM
