2007 F150 error codes
I have a 2007 f150 that just threw 4 codes of P0132 P0133 P2196 P2195. The truck runs and idles rough then appears to smooth out then rough again. Any help would be greatly appreciated.
Thanks, Jack
Thanks, Jack
<TABLE border=0 cellSpacing=0 cellPadding=0><TBODY><TR vAlign=bottom><TD width="100%">2007 F150 error codes <!-- END TEMPLATE: navbar_link --></TD></TR><TR><TD style="FONT-SIZE: 10pt; PADDING-TOP: 1px" class=navbar colSpan=3>
<!-- BEGIN TEMPLATE: navbar_link -->Reply to Thread <!-- END TEMPLATE: navbar_link --></TD></TR></TBODY></TABLE>
Also stalls at idle.
<!-- BEGIN TEMPLATE: navbar_link -->Reply to Thread <!-- END TEMPLATE: navbar_link --></TD></TR></TBODY></TABLE>Also stalls at idle.
For the P0132 code check this link - http://www.obd-codes.com/p0132
For the P0133 code check this link - http://www.obd-codes.com/p0133
Here's the meaning of the other 2 codes:
P2195 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 1)
P2196 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1)
Have you checked the wiring or replaced the O2 sensor to see if that helps? Also, since it's a 2007, is it still under the new vehicle warranty? It may also still be under the emissions warranty.
